Packy's Avatar
Broken Valve Spring
Anyone have a good thread on replacing valve springs and retainers on a 3.0? I did a search and have not found a good step by stepper on this.
This one has good info but I'm looking for a little more...
Broken valve spring? Valve cover surprise.
The motor is out of the car. Is this pretty straight forward? I know to rotate to TDC on each piston and then make sure the piston doesn't drop into the combustion chamber, but i don't want to use compressed air and it would be nice to see how others did this.
Much obliged.
-P
(1) '77 Chassis and '79 SC 3.0 project car
(1) '79 911SC 3.0 Widebody SC
(1) '15 Ford F-150 4x4 3.5TT
Toluca Lake, CA
Old 12-06-2010, 02:45 PM
I am by NO means any kind of accomplished DIYer but I think this is one of those things where if one spring broke it's probably best to replace all of them, not to mention the conditionof the valves themselves, etc... I guess what I'm saying is I think most folks send the heads out to a reputable shop and have everything checked and redone if needed.
Old 12-06-2010, 04:55 PM
Packy's Avatar
I plan on doing this myself. I know it isn't that hard. i don't want to take the cam towers off. I'm just wondering if anyone has a list to follow to make the job easier for me.
And yeah, I agree about changing all of them. I know the SCs had a bad run of valve springs and this isn't uncommon.
Toluca Lake, CA
Old 12-06-2010, 06:00 PM
NOLAsc's Avatar
Hey Packy,
That was me in the thread you listed. I used one of the lines from a Harbor Freight compression test kit to pressurize the cylinder. Easy.
You don't have to remove cam towers -- just the rockers. That's not hard either.
I'll pm my contact info.
"... changing without pain or agony not only in bulk and shape but in color too, approaching the color of wind ...."
-- William Faulkner
Old 12-06-2010, 07:51 PM
Retired Member
Charlie V's Avatar
Found broken parts in engine
This is what I did.
post 50 on the above thread walks one through the process. Spend the time and step through it. It is actually fairly easy.
Good luck.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine.
Old 12-06-2010, 09:56 PM
Max Sluiter
Flieger's Avatar
He has the thread- look at the first post. He said he wants more info than that thread can provide.
Old 12-07-2010, 12:02 AM
Packy's Avatar
I think I can figure it out from here. Once the valve springs are out I'll just tie the valves up so I don't have to keep constant pressure on the valve from the combustion chamber. I'm going to take all the springs off before I order new ones so leaving the compressor hooked up wasn't an issue. I want to see what is wrong and which parts need to be ordered after all the springs are out so I'm not doing them one by one.
Toluca Lake, CA
Old 12-07-2010, 10:54 AM
Grand Am/IMSA Data Guy
Porsche84's Avatar
I'd replace all the springs with better ones from EBS. I would use air to hold the valve when you use the spring compressor, then put a rubber band on it to keep it up while you wait for parts.
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 12-07-2010, 03:00 PM
NOLAsc's Avatar
Jerry,
With the EBS springs (not stock?), do you also need to get the spring height measurement tool and be prepared to adjust with shims?
Shawn
Old 12-07-2010, 06:50 PM
Or you could take the initiative to say that you are going to replace all the springs and leave them intact, order new springs, wait for their arrival and then tackle them one at a time.
Gary Kozun
83 911SC Cabriolet
Old 12-07-2010, 07:23 PM
Tags
broken valve , intake , spring
