SC brake fluid reservoir tubing
I have a tube on the very top of my brake fluid reservoir that looks as it functions for overflow. However, the terminus of the tubing has sheared off and I can't tell where it was supposed to end or how important the function of that tubing is. Should I pull it completely or where should I run the new line too?
cheers-
Old 03-01-2011, 01:58 PM
Bill Verburg's Avatar
cheers-
It dumps under the car, it's important to the extent that fluid level in the reservoir rises and falls w/ usage and temperature, you don't want excess fluid to dump into the trunk. Similarly there should be a line from the battery that dumps under the car.
For most street use and if the res. level isn't topped off there won't be any excess. Nevertheless it's best to replace that line
Bill Verburg
Old 03-01-2011, 02:25 PM
Wilhelm's Avatar
cheers-
I assume you know...make sure you dont get any brake fluid on your paint !
Old 03-01-2011, 02:42 PM
If you drive the car agressively (autocross for instance) brake fluid will slosh into the overflow pipe (or elsewhere if it's not there) even if the MS is not overfilled.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 03-01-2011, 02:43 PM
It may, not necessarily will
Bill Verburg
Old 03-01-2011, 03:16 PM
Great. Where should the line run in order to dump the fluid? As convoluted as the tubing runs, it seems as though it would take a fair amount of pressure to run brake fluid all the way to the end. And yes, NO to the paint!
Old 03-01-2011, 03:56 PM
Recreational User
porschenut's Avatar
here's a picture of where the tube exits the trunk. It travels along the top of the left fender and then exits forward of where the battery is. This car is an 86 Carrera, btw.
Old 03-01-2011, 04:27 PM
It would also "Spill" simply by pushing back brake caliper "pucks" while putting in new brakes. You tend to wear brake pads down slowly, and you "occasionally" refill the reservoir. At some point, the reservoir may be "full" and the old brake pads are "worn"...and you proceed to change out pads and put "fat" new pads in....that's when the overflow will then spill into the car without a vent line.
The vent line runs along the front/driver fender seam near the trunk lid cut-line....and finds its way to the front of the car near the battery and disappears to a very small opening to the outside. Truth be told...if I didn't have an original line to follow, it would be very difficult to trace.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-01-2011, 04:28 PM
Max Sluiter
Flieger's Avatar
Wonderful that Porsche was still dumping brake fluid on the ground in 1986.
Old 03-01-2011, 06:54 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
I have a small bottle mounted next to the brake booster and have the end of the overflow line run through a hole drilled in the cap. Its a track car so there is constantly fluid coming out of the hose from heavy cornering. Even for street use I used to get brake fluid all over the bottom of the car when the tube ended underneath. The underside of the car was full of it. A poland spring bottle served this purpose very well for a bunch of years.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 03-01-2011, 08:54 PM
schumicat's Avatar
that is why you should remove some fluid from the reservoir with a dedicated turkey baster before you push the piston back to fit new pads. On my car the PO capped the nipple for the "overflow" line. Anyone have a photo of exactly where the line connects to the fender? The photo above shows where the line runs, but not where it connects to the m/c. Thanks
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-02-2011, 04:56 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
I have my breather line capped off and a super small hole drilled right thru the top of the reservior cap with the smallest drill bit I could find.
After a DE i might have a little bit of residue in the bucket surround around the cap.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 03-02-2011, 07:50 AM
I know the drill when putting in new pads.....not everyone does, so the point being made is that having the normal vent "line" installed is a good thing..... as it serves to limit any damage regardless of whether one was conscious to remove some brake fluid or not.
Wil Ferch
Old 03-02-2011, 09:07 AM
I simply replaced the entire drian line with a shorter version in the shape of a kitchen sink trap. I snaked a coat hanger wire into the rubber line so it would keep it's shape and I stuck some cotton in the open end as a filter. Works fine.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 03-02-2011, 09:43 AM
