Send a message via Skype™ to SorenDK
Right camfeed oilline too short?
I have a problem someone might have a fix to.
I am upgrading a 2,0 1969 E engine to carrera, oil-feed chain tensioners only to discover that the right side cam oil line is too short!!...
I have done some investigation and found the in some cases there are a oil pressure sender block mounted in between...
I think its this one...
911 107 704 00
However my oil pressure sender is mounted on the rear, right side (oil-in) and I dont really want to move this part from there...
Question: Has anyone encountered the same problem - Im thinking that a simple distance piece of about 4 cm between the engine block and the original oil-line fitting could do the trick?...
Hope you guys can help :-)
Old 12-13-2010, 06:14 AM
Use the pressure block and plug the sender hole.
Old 12-13-2010, 06:54 AM
OK - but really... there must be a smarter way... Im thinking about making my own distance piece... it should'nt be much more complicated than basically threading a small pipe in both ends... perhaps with a little finesse :-)...
Is there really no one outthere done the same? - pics are appreciated
Old 12-13-2010, 07:19 AM
tharbert's Avatar
I ran into the same issue when I upgraded my 72. Call Pelican. There is a correct line you can use to avoid plumbing it yourself. As the longer line was the same price as the shorter one, I returned the unused line from the kit and they sent me the correct line.
Edit - I don't know if you bought your kit from Pelican Parts or not... but they stocked the correct line. I actually had the same thoughts as you...trying to plumb it myself. The longer line is a much more tidy and "correct" alternative.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
The problem is that I did not buy from our host... I live in Denmark Europe :-)
Is there a partnumber on that longer line?
Old 12-13-2010, 07:35 AM
tharbert's Avatar
Pelican offers this as an OEM local p/n "PEL-CLIN-KTN" but I also came across the Porsche part number 930-107-348-10.
My post...
More reading
72 911T 2.4 MFI
Old 12-13-2010, 08:42 AM
Thanks tharbert :-)
Old 12-14-2010, 02:20 AM
