ducktail ctr/997rsr build thread
Since my session timed out by the time I tried typing this up before important points first:
non-sunroof 912e bolt on plastic undertray for the whole bottom of the car 10.5 and 11-12 inch flares subaru motor (cheaper in the long run if I ever need to replace it) gt racing bumper for 11 inch flares cut out to resemble the 997 rsr "smile" plastic/rubber sideskirts/rockers ducktail antenna changed to central roof antenna electric power steering flat yellow on flat black paint, white or black wheels more to come later pot shots, feedback and opinions welcome PLEASE do not move to 912 forum where this thread would rot away from lack of feedback Last edited by DucktailCTR; 01-13-2011 at 05:16 PM.. |
Max Sluiter
Why are you making a 997? Why not a wide-body yellowbird?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Speaking of 997 ducktails... does anyone know of any domestic manufacturers making a replica of the "997 Classic" ducktail that the factory introduced recently?
Jeremy ![]() 1971 911 Wide One 2.7 2012 911 Cabriolet 2011 Cayenne S |
sounds like a very labor intensive project. is this just for fun or for a specific competition class?
in my opinion, no reason to substitute a non-porsche motor when you're going to such great lengths for the rest of the car. Call me a purist, but just my 2 cents.....
2002 Porsche 911 turbo 2007 Porsche Cayman S track car 1987 Porsche 924 Carrera GT tribute 2015 BMW X5 |
Location: Fly heading of 221 degrees out of Sebring until you see big water.
Starting to gag on sushi....
as for a porsche motor... i should hopefuly be able to learn to maintain it myself without a shop. But it's about cost. Cheaper now and cheaper in the long run as far as I know for a subaru. but a subaru doesn't look like a porsche 911/912 and thats why I didn't buy a subaru instead. Last edited by DucktailCTR; 12-16-2010 at 03:44 PM.. |
Because i don't like big wings. I might use the yellowbird front bumper, but biggest I'll go is an idea I've had of an x-large ducktail with a built in wing. a ducktail with somethin like the adjustable spoiler part from this that's sticking up in the back
![]() and why styled after the 997 rsr? Because i like the way it looks and I like the idea of a car with a smile.
Max Sluiter
Max Sluiter
I think that would look silly, especially on a wide-body. You should either do a simple ducktail or one of the ducktail+banana wing setups if you track the car.
Max Sluiter
paint scheme would be almost exactly like this
I'm in the middle of a group 5 BMW 320 replica build. I've already got the front fender flare plugs made, now I just need to make composite flares. share your secrets and techniques. are you doing a lot of composite work?
composite like fiberglass and cf? and secrets and techiniques for what? keeping the cost down? basic bodywork? painting?
Max Sluiter
So would your banana wing be removable? If you think a Yellowbird tail is too large, then I would think you would only be using the wing for track work.
There is someone here on Pelican who put a ducktail on, then had removable wing stays with a home-made carbon fiber airfoil. I lost that photo with my laptop's hard drive.
are you going to be building a fully custom body with steel? ABS plastic? composites like fiberglass or carbon? how are you laying it up? how are you curing it? are you molding?
only asking because a fully custom body can be a hell of a lot of work, and carbon fiber requires heat and pressure to cure from what I've read. if you're riveting pre-made flares to the fenders, then that's a piece of cake.
no bananana. just a duck with the outside area of the duck black and the scooped area yellow |
doesn't sound like function is the priority here, I think he has an idea of what he wants it to look like and ........
Best of luck with the endeavor ... |
