exhaust studs broke-Help :(
I was taking my old heat exchangers off today to make room for SSI's and One of my studs broke flush to the header flange, 4 studs backed completely out, and the rest of the nuts came off easily. Since there is a little meat left on the stud that brok do you think i should weld a nut onto it and then wrench it out? While im in here should I replace all the studs or will they probably break? Or just do the ones that backed out? What is the technique for installing them? red loctite or anything? Trying to get back on the road asap, thanks in advance you guy sare the best.
Old 12-17-2010, 03:30 PM
AlfonsoR's Avatar
From a specification standpoint, it's difficult to comment since the alloy grade is not mentioned. Maybe you can call Pelican and they can tell you what it actually is?
On welding the nut ..... I'm sure others will chime in since this is not uncommon. Just be very cautious, if you do weld, make sure you have a good ground close the stud you are working on. Otherwise, current could find a pathway across your bearings. As a matter of fact, that should be one of my questions: where is the best place to ground?
Old 12-17-2010, 03:58 PM
If welding doesn't work this may be of interest.
Does anyone sell a fixture for drilling broken exhaust studs
Rick
88 Cab
Old 12-17-2010, 04:03 PM
RETIRED
Joe Bob's Avatar
There was a few recent threads on this. Do a search.
MY best suggestion is to get a flat piece of steel, drill a hole the size of the stud and then place it over the stud. Weld a big old goober over it. THEN using MAPP gas, slightly tighten and then back it off.
Otherwise you'll need a jig and a drill.....or an extractor. There are a couple of people who have jigs for sale or rent and the threads have links to new units.
Those fasteners are nice, pricey.....depends on how many times they will be on or off.
2012 ML350 3.0 Turbo Diesel
mca mca is offline
mca's Avatar
Regarding the new exhaust studs, just make sure that they are the right length for your SSI flanges (thick or thin?).
I installed new exhaust studs during my rebuild. Used loc-tite (red I think) on the stud threads going into the head. Then used a bit of anti-seize on the exhaust nuts. This helps prevent the stud from turning out of the head if you have to remove the nut in the future.
Good luck!
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 12-17-2010, 04:06 PM
Capitalist and Patriot
911Freak's Avatar
Here's some good info:
Broken Exhaust Stud (picture)
A tail of burnt spaghetti and broken exhaust studs.
I'll be doing this very soon and prepared for the inevitable by reading these threads and the one listed above by Joe Bob
Good luck and post up your progress!
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 12-17-2010, 05:28 PM
jsveb's Avatar
Hi
I used EDM, which simply removes the broken stud by means of electricity. It is an awesome piece of equipment. Hard to find though
Old 12-17-2010, 05:39 PM
I dont have access to EDM, but i have penty of welders and such available. opinions in this tool?- Laser Tools | 3986 | Impact Stud Extractor 1/2"D
Im not going to be taking the SSI's off for years hopefully, but what is the part number for stainless studs from ARP? I cant find it.
Should i replace all and risk breaking the ones that stayed in or just fix whats broke...following the saying dont fix what aint broke?
I will try welding the nut, a friend is a expert welder. It that doesnt work ill try the extractor or welding a tab on....then i guess i have to break out the evil drill...sound right?
Thanks fopr all your help through this harrowing experience...lol
Old 12-17-2010, 09:44 PM
SP2 SP2 is offline
SP2's Avatar
Get Christian's tool. It's perfect for drilling out the stud without damaging the threads.
Old 12-17-2010, 10:51 PM
