rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Recommendations for Cordless Impact Driver
I have a compressor in my garage, but frequently work in my driveway which is quite far away. I'd like to get an 18V cordless impact driver for $200 or less that can remove lugs. I know the SnapOn is great, but that is way out of my price range. Suggestions?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 11-29-2010, 05:55 PM
Griffinroydonal's Avatar
We use the Porter Cable brand in the shop and get very good service out of all the tools. I have asked Santa for a set to use at home.
Warning - I play with Porsche's
1970 -914 / 1982 -911
1984 -928 / 1987 -928
Old 11-29-2010, 06:04 PM
MBruns for President
JeremyD's Avatar
Ryobi has a new Impact driver out - 18V 200 ft lb torque
I like it because I have one battery (actually two in chargers all the time) and use them for (cordless drill, vacuum cleaner, spotlight, Saw, zip sawetc.)
Old 11-29-2010, 07:13 PM
Both Makita and Dewalt make one that work great! I've used them for several years now on anything from P-car work to Jeep suspensions.
Can't beat the price either...
Old 11-29-2010, 07:17 PM
Impact driver
I use a DeWalt for the same reason, have other 18.4 tools and a couple of batteries. BTW rebuilt batteries can be built with more power (amps?)
Old 11-29-2010, 07:49 PM
Milwaukee works great for me.
2002 Porsche 911 turbo
2007 Porsche Cayman S track car
1987 Porsche 924 Carrera GT tribute
2015 BMW X5
Old 11-29-2010, 08:41 PM
It depends on the torque you are trying to apply. 200lbs or more then air impact is unbeatable.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-29-2010, 08:54 PM
bgyglfr's Avatar
Milwaukee 2662-22. 450 ft lbs torque. Works great. Just be careful what you tighten with it.
70T 2.7RS spec.
68L coupe
Old 11-30-2010, 04:22 AM
tharbert's Avatar
You are better off running the nuts on by hand.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 11-30-2010, 04:39 AM
1966 - 912 - SOLD
lane912's Avatar
i use a corded dewalt impact. if the cordless ones are that good now i might have to step up...
i was too tired to be pretty last night!
Old 11-30-2010, 06:38 AM
rs6er's Avatar
This I know.
John
Old 11-30-2010, 07:05 AM
arbita1's Avatar
I've used that one for a few years now. It's the DW292. It has 345 ft-lbs torque. I recommend it if you don't need the cordless feature. The cordless version has 300 ft-lbs.
They also make a smaller cordless version that has 145 ft-lbs. I want this one for the track. Great for changing tires.
Matt.
83 911SC
85.5 944 NA - Sold
Old 11-30-2010, 07:32 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
I have the 24 volt Dewalt cordless. Can't get more powerfull then that. Switches from impact to regular with a switch.
Chris
73 911e
Old 11-30-2010, 12:28 PM
Group555
Scott555's Avatar
Send a message via AIM to Scott555 Send a message via Yahoo to Scott555
I'll just throw this out there, because my haste bit me in the butt...
Around here, the term "impact driver" refers to something that you use to screw or bolt, as in construction. Like drywall guys and construction will use them because they have more torque to drive a screw into harder surfaces.
I was at the local Lowes and they had a set of really nice Hitach li-po tools...so I buy the drill (my makita was stripped anyway) and the "impact driver" thinking I'd use it under the hood, etc, etc... Definitely not the same. I have since found many uses at home, but it wasnt what I was thinking.
I ended up buying the Snap-On version you mentioned for my "impact wrench" duties. If you call your local SnapOn truck guys, they may have a used version for cheap. That's what I did. The local driver had a buy-back because some young mechanic quit the field and couldnt afford all the tools he'd "tabbed".
Old 11-30-2010, 01:04 PM
Zeke's Avatar
Good point on the difference between an impact wrench and driver. I think the 24v wrench versions are just hitting the market.
And, AFA I can tell , it's OK to run nuts with power up once they've been threaded on the stud a turn or so.
"You are better off running the nuts on by hand." That does make it sound like threading them all the way to snug.
Old 11-30-2010, 01:24 PM
rs6er's Avatar
I learned that today while browsing at Lowes. I was hoping for a tool that could do both. It doesn't exist, although I don't know why it couldn't, by using adaptor chucks.
John
Old 11-30-2010, 02:59 PM
bgyglfr's Avatar
You are correct. They are much better for taking bolts of than putting them on. I sold one to a guy once. He was installing a railing into concrete. He drove an anchor into the concrete until it snapped. Then he said, "I'll take it".
70T 2.7RS spec.
68L coupe
Old 11-30-2010, 03:05 PM
RETIRED
Joe Bob's Avatar
Break them loose by hand, run them off with a cordless. The cordless impact guns do a run up, whack, run up whack.....then they die. Trust me....been there done that....
2012 ML350 3.0 Turbo Diesel
Old 11-30-2010, 03:16 PM
bgyglfr's Avatar
Voltage doesn't always mean more power. Impact is based on the front of the driver. The spring mechanism and the hammer design is what creats the impact. The harder the hammers hit, the greater the impacing ability. The Milwaukee 18v (450ft lbss) actually impacts harder than their 28v (325ft lbs). The 18v is newer and incorporates their newer hammer design in the front end. Then there is the 18v impact driver at about 100ft lbs. That is the tool for driving nuts, lag bolts, etc. Sorry if I come off as a know it all. I sold these for 5 years.
Impact Wrench
Compact Impact Driver
70T 2.7RS spec.
68L coupe
Old 11-30-2010, 03:19 PM
iamchappy's Avatar
Smoking deal on this Dewalt:
DEWALT DW059K-2 1/2" 18V Cordless Impact Wrench Kit | ToolBarn.com
But for 42 bucks, i have been using one of these for the last two years, just used it today to mount my snowtires
on my Jeep, the battery is dying so it's only good for one tire change but it still gets it done kinda,
it worked way better when it was new. Ive been thinking about springing for Dewalt.
GOODYEAR 24 VOLT CORDLESS IMPACT WRENCH SET - JCWhitney
If money was no object i would buy an Ingersol Rand
Just checked that Goodyear impact gun price was for the battery, they want 124 for the gun, i paid 70 for the whole kit at PepBoys
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 11-30-2010, 03:35 PM
