-   -   HID build,.. (http://forums.pelicanparts.com/porsche-911-technical-forum/582124-hid-build.html)
gsmith660 12-27-2010 04:26 PM
I can testify that the retrofit source people are good people and very helpful that is where I got my kit from and it worked great.
Originally Posted by GaryR (Post 5749546)
Great info, and the suppliers look like they are really helpful with the installation and have all the relays/wiring you would need. I'm going this route on my RSR road car.
GaryR 12-27-2010 04:32 PM
And that one projector does both high and low beam, yes?
jimtweet 12-27-2010 04:35 PM
it has to be a bi xenon projector and a bi xenon HID kit...that is the only way,..
but yes, mine will do both,...
GaryR 12-27-2010 04:40 PM
Got it, it's the "bi" thing that is key..:D
jimtweet 01-04-2011 01:18 PM
very small update, sorry
i ordered the wrong bulbs, and was sent the wrong harness, so waiting on correct parts,..
i had some paint problems with primer sticking to the actual reflector, so i had to strip them all down and start over,..
but i did get the housings painted, new seals, new lens installed, the housings are painted a dark metallic grey color, hard to tell from the pics
http://forums.pelicanparts.com/uploa...1294175873.jpg
bfunke 01-04-2011 04:54 PM
Jim - great work; keep posting your pics.
GaryR - Yes the BiXenon projectors do both hi and lo beams. The bulb has only one output but the high beam signal powers a small motor in the projector which moves a masking shutter inside the projector to provide the correct light output. Some of the newer projectors even have auto leveling sensors to adjust the beam for different loads and ride heights.
jimtweet 01-15-2011 06:28 PM
well had a change in plans, i guess i shoulda listened to that measure 40 times thing...i did not work in the extra inch for the bulb and socket, grrrr and was about a inch short on the passenger side with the oil cooler...:mad::mad::mad:
anyway, got a set of new shrouds and re mounted the projector inside the old housing
had to trim A LOT of the shroud to get it to fit the projector, since these were not meant to fit together
http://forums.pelicanparts.com/uploa...1295144728.jpg
light inside housing
http://forums.pelicanparts.com/uploa...1295144775.jpg
holes drilled to mount
http://forums.pelicanparts.com/uploa...1295144817.jpg
mounted with shroud
http://forums.pelicanparts.com/uploa...1295144840.jpg
jimtweet 01-18-2011 02:22 PM
one light done,..I LOVE THE WAY THEY CAME OUT,...:eek::eek:
http://forums.pelicanparts.com/uploa...1295389337.jpg
drcoastline 01-18-2011 02:28 PM
Jim,
That is amazing work. Looks OEM.
jimtweet 01-18-2011 02:35 PM
Originally Posted by drcoastline (Post 5792689)
Jim,
Thta is amazing work. Looks OEM.
thank you, i just hope they perform as good as they look:rolleyes:
Jim,
where in new jersey are you? i live in cherry hill
drcoastline 01-18-2011 02:41 PM
Howdy neighbor SmileWavy Washington Township near 55 and 322. Moved from North Wildwood about three years ago.
jimtweet 01-18-2011 06:54 PM
your not far at all, well have to meet up sometime!
drcoastline 01-18-2011 07:14 PM
Not to far. We should meet up. I would love to see your lights up close. Are you a PCA member?
jimtweet 01-19-2011 04:50 PM
i am not a PCA member, but yes as soon as the weather gets a little better ill take the ride down
drcoastline 01-19-2011 08:26 PM
I was asking to see if there were any type of regular get togethers in the area? I am shooting to have my car back on the road in the spring hopefully we can go for a drive.
midnight911 01-19-2011 08:53 PM
sub'd.
can't wait to see it on the car. Great work jim!!! and thanks for sharing.
tobluforu 01-20-2011 04:52 AM
The one light projector looks great, good job. But how do you aim it, does the piece it attaches to swivel?
GaryR 01-20-2011 08:47 AM
As he uses the original bezel I would have to assume the adjusters still work the same way (as long as the HID is mounted square). Is that correct?
jimtweet 01-20-2011 10:50 AM
this is correct!
