o2 sensor etc.
Hello guys!
I have a couple questions about o2 sensor, and removal of it. My car is a 1978 SC with a 3.0 SC engine, not sure of the year of the engine, it has been swapped. This year, I removed the CAT, and later on I swapped the exhaust. I could not see an o2 sensor in the cat, but there was a small pipe exiting the muffler itself. Just out of curiorsity, where is the o2 sensor located, and what was the pipe exiting the muffler, at this stage it is temporarily bent to the side.. I would expect the o2 sensor to be in the cat, at the time of the cat removal I gathered earlier owners had gone to the trouble, removing the sensor and adjusting the motor to that. Thanks! Cheers, Jarle |
I don't think that your 78 sc has the ox sensor... didn't only start in 81?
David 1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit 1981 Black 911sc (sold) |
It also definately had a cat, that's for sure. But there was no sensor in the cat, and neither in the ex manifold. Anyone know the different locations here on different models? Thanks! Cheers, Jarle |
My understanding was that the O2 sensor should be as close to the exhaust manifold (but in the cat) as possible to help it heat up. I really don't know if it's been done differently.
There should be a 30-40cm cylindrical connector for it on the left rear fender near the coil or fuel filter. Is yours attached to anything?
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Hmm.. That small diameter pipe exiting from the exhaust\muffler did that have something to do with the airpump perhaps? Thanks! Cheers, Jarle |
Jarle,
Look at your engine and find the type number and serial number. Then, we'll know what you have in there. The '78 and '79 SC in some markets had a cat but it was different than the ones used in 1980 and later, when the O2 sensor was used. Shoot a picture of the muffler also, there were a couple different ones that had a small pipe going in to them. JR |
Will shoot a photo of the enginenumber tomorrow. Hopefully that should shed some light on the matter. Regarding the small pipe to the muffler, anyone know what it's for? Thanks! Cheers, Jarle |
JR |
Found this number on the engine: 930 105 111 0R What does that tell us? The muffler is a turbo muffler I think.. Including a picture of the end piece here.. Do not have it available you see. Thanks for the info guys! Cheers, Jarle
Jarle,
That's not the engine number, it's a number cast into one of the engine case castings. The engine number should be something like 930.XX and you should find it stamped on the engine case, to the right of the cooling fan. The engine serial number will be nearby and will probably be 7 digits. That does look like a turbo muffler, in which case the extra pipe was for the output of the wastegate. It would need to be capped on a normally aspirated car. Thanks, Jeff |
63D 4945 930\10 Did not see anymore numbers close to this location. Both numbers where close to the fan, on the right.. Are these the numbers I'm looking for? Happy newyear everybody ![]() Cheers, Jarle |
Not US from what I can understand? Not even cat's? Apparantly when they swapped in the donor engine, they didn't connect the o2 sensor simply because there is none? But the cat was just left there. Are my assumptions right here? Thanks guys! Cheers, Jarle |
It would be interesting to see some pictures of the exhaust system. A turbo muffler won't bolt up to a stock SC exhaust. Cheers, Jeff Last edited by javadog; 01-01-2011 at 07:21 AM.. |
Earlier there was an insane turbo engine in the car. They didn't want to sell it with that engine because it was more than a handfull to drive. My guess is that they kept everything they could, so probably fitted the muffler somehow instead of buying a new exhaust. I have since then fitted a Dansk sportmuffler with the 84mm pipe. Actually I'm sort of relived the engine is a non o2 sensor type. Less things to worry about ![]() Thanks Java for your help. Cheers, Jarle |
