-   -   What engine oil do you use and why, not asking which is better, just curious (http://forums.pelicanparts.com/porsche-911-technical-forum/583272-what-engine-oil-do-you-use-why-not-asking-better-just-curious.html)
bsimonson 01-03-2011 01:30 AM
I use a locally available oil, Agrol Super Syntet 5W-40. It's a SHPD-oil with all the right additives. I believe that synthetics are superior in many ways and I want as good lubrication as possible when the engine is cold, hence a 5W oil.
stlrj 01-03-2011 02:45 AM
Any brand off the shelf 10w30.
Why? Best lubrication at cold start where most wear occurs and cooler operation due to less internal friction, eliminating the need for anything more than a stock fender mounted trombone oil cooler.
Cheers,
Joe
74 w/ 86 3.2
craigturbo02 01-03-2011 02:54 AM
Mobil 1 15/50 always used it.
jleonej 01-03-2011 04:53 AM
I know, I know not another oil thread but I was just curious as to who uses what brands. I am not looking at changing what I use or anything of that nature. I don't want to know who thinks what brand is best, I was just curious as to who uses what. I happen to use Mobil 1 in my 86.
esample 01-03-2011 08:59 AM
Why, Brad Penn of course.
-e.
cmcfaul 01-03-2011 09:51 AM
No Mobil V-twin 20-50 users out there. Thought this was a full syn designed for air cooled engines with lots of zinc. A bit pricey though
Chris
73 E
GaryR 01-03-2011 09:55 AM
All I use is V-Twin in my race car
WIL84911 01-03-2011 10:49 AM
Royal Purple 20 50 but it's no longer on sale so I may be switching.
aigel 01-03-2011 12:00 PM
On the SC I ran Castrol GTX 20W50
On the 993 I run Mobil1 15W50
George
aftermath 01-03-2011 12:00 PM
AMSOIL
AMSOIL - SAE 20W-50 Synthetic Premium Protection Motor Oil (ARO)
Hi zinc formula.
You can order from me :)
cattman 01-03-2011 12:24 PM
Mobile 1 15-50.
I use it on both my Supercharged 997S and my '97 911. I buy it in the 5 qt jugs at WalMart when it's on sale.
CATTMAN
p911dad 01-03-2011 01:29 PM
I also use the Mobil 1 V twin 20w50. I get it from AutoBarn.com.
86 911 Targa 01-03-2011 02:54 PM
Mobil 1
Mobil 1 decades!
dshepp806 01-03-2011 03:21 PM
I like simple questions///(right?)
BP 20 W50,..in the South,..all year,..every 3k miles...no cold starts below 25 degrees F.....(but that;'s just me).....
Definately: no additives,....(aside from healthy injections of Techron....)
Best,
Doyle
HarryD 01-03-2011 07:27 PM
Originally Posted by barndoor (Post 5760216)
Veronika only uses Brad Penn in her '76 911S......
errrr... what car?
HarryD 01-03-2011 07:29 PM
Cliff Notes for Oil Selection
Cliff notes version:
Older engines (pre-mid 90's) need high levels (around 1200 ppm plus correct level of detergents) of Zinc (Zn) and Phosphorus (P) to protect cams and other high pressure surfaces.
With the introduction of roller tappets in most engines by the mid-90's, this requirement is relaxed and Zn and P levels can be reduced. The EPA pressured API to reduce the Zn and P levels to (hopefully) extend the life of the catalytic converter which is poisoned by Zn and P. They complied.
Use 20W-50 or 15W-40 oil. Brands frequently sugggested here, in no particular order, include:
Brad Penn 20W-50
Valvoline VR-1 20W-50
Kendall GT 20W-50
SWEPCO 15W-40
Royal Purple
There are others as well.
Milo2361 01-03-2011 07:56 PM
I had emailed shell about their oil and Zn and P content, received an email next day from them saying it is rated at or above 1200ppm. Ive been using Shell Rotella T 15w-40 basically since i acquired the car(10w-40 when it gets damn cold in NE). no problems yet, oil change intervals of 3-4k miles. cost is around $2.50 a quart.
Neel 01-03-2011 09:11 PM
Since you asked, Royal Purple..
m110 01-03-2011 09:39 PM
Brad Penn 20W-50 because people I trust use it...the threads seem to indicate it works well and it is relatively cheap for me.
Swepco 306 15W-40 also seems to work accoording to the experts, a little more pricey for me. If changing oil hyperfrequently I don't think it really matters, as long as it is heavy.
