plumb4u2's Avatar
little help with idle
I just performed major maintenance on my 84 and need a little guidance.. here is a list of what I did.
removed entire CIS system
valve adjustment
new plugs (standard copper plugs from our host)old plugs where platnium
new clewett plug wires
new oil pressure switch
new thermastat o-ring
new breather cover gasket
new dist. cap and rotor
replaced every oil seal except main seal
new fuel filter
reinstalled CIS and resealed with 12 new gaskets and six new spacers
when I first started car it ran real bad would barley idle, figured i had vacuum leak found that intake studs where loose, retightned all 12 intake nuts and that solved vacuum leak
here is my concern now
when I start car cold it hunts for bout 5 min then settles to bout 700 rpm, I think this idle is too low before all this work was done it idled at bout 900 and sounded much better..I also think it is running rich now, I can smell it bad
does the mixture need to be adjusted? i did not mess with that at all
could some of the new parts I installed changed settings?
The main reason I did all this work is because I bought car in June and dont have service records so wanted to start off clean plus the oil leaks where driving me crazy and I also wanted to take it apart to get experience with my engine
TIA ffor any input
Justin
84 Carrera Targa
98 F-150 4x4
Old 01-02-2011, 07:24 PM
Band.
Can you take a picture or clarify?
84 does not have CIS. 84 is the first year of Motronic. So . . . . . . .
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 01-02-2011, 07:30 PM
plumb4u2's Avatar
My bad it is motronic (thought CIS was cold air intake)
This is what I meant I removed the intake manifold system
Justin
84 Carrera Targa
98 F-150 4x4
Old 01-02-2011, 07:46 PM
plumb4u2's Avatar
Justin
84 Carrera Targa
98 F-150 4x4
Old 01-02-2011, 07:48 PM
steely's Avatar
Nice car, and nice job sprucing things up like that!
The low idle could be a vac leak (since you were in there).
I'd double check the lines for connections/breaks, and the rubber connecting the two intakes together. Check the idle position switch response and the CHT.
I would not adjust the idle at this point.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 01-02-2011, 09:09 PM
plumb4u2's Avatar
Thanx for comment on car....I willdouble check for vac leaks....can u explain idle switch and cht check?
Justin
84 Carrera Targa
98 F-150 4x4
Old 01-03-2011, 10:23 AM
plumb4u2's Avatar
was just messin around in the engine and sprayed some carb cleaner around breather cover and the idle raised so I will take air box off again to gain access to those bolts...will this small vac leak cause rich mixture condition?
Justin
84 Carrera Targa
98 F-150 4x4
Old 01-03-2011, 03:13 PM
dshepp806's Avatar
Torque them... carb cleaner is your friend.....
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-03-2011, 03:19 PM
steely's Avatar
Originally Posted by plumb4u2 View Post
Thanx for comment on car....I will double check for vac leaks....can u explain idle switch and cht check?
The idle switch on your 3.2 is on the left of the throttle housing under the linkage - you may have seen it when you removed the intake. This switch is supposed to be in the closed position when the throttle is idle. with the engine off, move the idle linkage yourself and listen for a click and/or test for closure at it's connector. The DME uses this as an indication of idle.
The cht or cylinder head temp sensor is connected to the bracket on the left of the intake. I thought that you may have disturbed this during intake R&R, and poss. caused an altered idle.
If you have a Bentley manual, nicer than haynes or chilton, it helps you troubleshoot it.
Dan
Venetian Blue
Old 01-03-2011, 05:39 PM
steely's Avatar
great minds!
Dan
Venetian Blue
Old 01-03-2011, 05:43 PM
plumb4u2's Avatar
thanx Steely...i did find small leak round breather cover so i will take off air filter box tomorrow and tighten those nuts and c what happens...I appreciate your input...I had so much fun taking off intake and getting so experience on how this thing works...what part of SE PA are you I live bout 25 min from york and drive to lancaster on regular basis
Justin
84 Carrera Targa
98 F-150 4x4
Old 01-03-2011, 06:01 PM
steely's Avatar
I hope that's it (breather) for you. And yeah, I agree with you on the top - I wished I'd cleaned the bay as well as I did the top, so I might have to do a modified version of it so I can get back in there. was a good feeling. I'm east of you in horsham, and travel back/forth King of Prussia.
Dan
Venetian Blue
Old 01-03-2011, 06:51 PM
plumb4u2's Avatar
thats cool....king of prussia is where I bought my car
Justin
84 Carrera Targa
98 F-150 4x4
Old 01-03-2011, 07:05 PM
