Optical/Pertronix Question - 1972 911
I am about to order the Ignitor (1) from our host. I have a couple of questions:
1) This is the only model that will work correct? 2) Do you have to remove the distributor to do the install? 3) Is there anything else I need to purchase at the same time? 4) Any tips/warnings etc? Any one ever done this on an early 911? Any info would be very much appreciated - ignitions are not my specialty!
David 1972 911T/S MFI Survivor |
Quantum Mechanic
The pertronix unit will replace the conventional contact breaker points in your dizzy with a hall-effect magnetic pickup.
I do not think it will work on a CIS-equipped car, and very sure it won't work on an 84 and later DME car. So if your car is a 72 or earlier, it might work. The 356 gang uses these quite a lot with excellent results. However, many advocate carrying a spare set of points in your "travel kit" in case the unit fails. Yes, you'll have to remove the dizzy, and you'll have to re-time the ignition after you install the pertronix. Be careful and read the instructions - there's a possibility of frying the unit if you install it backwards.
Mark Petry Bainbridge Island, WA 81 SC Last edited by mpetry; 01-03-2011 at 11:34 AM.. |
Band.
I've done it, and it is easy.
You can definitely do it on CIS cars, up until SC distributors that don't need it. Just check your distributor # and make sure you order the right one. You - can - do it with the distributor in the car, but if you know how to set timing etc., it's much easier to pull it out instead. You need some wiring stuff, maybe some heat shrink or barrel connectors or something, you need to get a power wire over to the fuse box. Here's my most recent thread detailing the problems I had because I ordered the wrong one, and when I finally got it happening. Pertronix and 008 distributor AGAIN
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
I'll get grief for this but here it goes anyway. THEY SUCK don't waste your money.
The black magnet that slips over the cam is to high and you have to trim down the rotor, it fits so tight that they some times break while sliding over the cam. No matter how may times I adjusted the two units I installed on on my 2.7 there was a slight stumble on acceleration caused by the pertonix. I and II. Points are cheap and they work fine.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Band.
That's true. I have mine in the glovebox, as everyone suggested for when the pertronix fails.
In maintenance phase
Do it. There are no moving parts, it does not wear, and the timing stays where you put it. It's a great system. -Dan |
Best upgrade EVER!
Points are such a PITA. I stalled the Petronics on my 73, 5+ years ago and never looked back. Fits perfect, installed in under an hour. Car runs great all the time (that just adjusted the points feel all the time). Chris 73 911 E |
I wouldn't trim the rotor - trim the Pertronix piece. Works great, even with CIS - but I'm not sure why CIS would make any difference???
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
I would rather be driving
I vote for the Crane optical. Mine has been bullet proof for the last 10 years. - In both cars!
There are no installation issues with the optical window wheel attaching to the distributor shaft. Yes, getting rid of points is top of the list as far as upgrades are concerned.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
