frz frz is offline
Wink how can i make my SC roar
how can i make the SC sound great?
what improvements can i make with out a full s/s exhust
can i squeeze a little more out of her performance
frz :>
Old 01-29-2002, 03:01 PM
I have a 1985 Carrera, I'm very happy with my stock muffler modified with a new exhaust pipe welded to the right side. It sounds good and there is a noticeable increase in power coming in at about 4000 rpm. On a USA Carrera, a modified twin pipe exhaust coupled with a a Euro pre-muffler gives about 12 -15 hp additional ( per B. Anderson). For details, see my earlier posts on this subject on this website. In the USA the muffler mod cost me $200, but some have had it done for less than $100. Cheap way to get some good sound and a bit more HP. I don't understand why so many people here in the US go to expensive aftermarket mufflers and SSI setup on a Carrera. You can achieve nearly the same HP increase with modified stock muffer (dual outlet) and Euro pre-muffler. On a SC the results may be a slightly different but I doubt if the aftermkt muffler + SSI is cost efficient. Lot of additional money for a bit more HP. Convert your stock muffler to a dual outlet and see what happens, you might be pleased.
DANNOV
Old 01-29-2002, 05:46 PM
rstoll's Avatar
Knock the stuffing out of your cat and hang on a Bursh Carrera muffler.
Robert Stoll
83 911 SC
83 944
Old 01-29-2002, 06:03 PM
Senior Member
Superman's Avatar
From all I've read, it sounds like the SSIs are necessary for power gain on an SC. On an SC, I doubt that the muffler change alone would increase power much.
I will agree that knocking the stuffing out of your CAT will improve the sound. It gave my car that deep, hollow 'big block' sound. Particularly at idle. Sounded pretty serious. It did not improve noise or volume at higher RPMs though.
Mocha 1978 911SC. "Coco"
Old 01-29-2002, 06:58 PM
Over the past 18 years I have owned both a 1977 911 (3 yrs) and a Carrera (15 yrs), and I think the stock muffler is not only wimpy sounding but also very, very restrictive. With the exception of the Bursch (a loud low quality muffler that will soon rust away), aftermarket SS mufflers are very expensive. I urge an SC or Carrera owner to modify the existing stock muffler with a dual outlet. It is cheap, and you will hear the difference, and if you are really atune with your automobile you will also feel it. YOU DON'T NEED TO SPEND BIG BUCKS ON A FANCY MUFFLER. On the SC I agree the SSI heat exchangers will gain more HP than on a Carrera, but you pay a lot for those horses. Paying big bucks for a aftermarket muffer is a waste of money and SSI heat exchangers add to the pain. The way to go is modified stock muffler, combined with cat bypass or euro pre-muffler, and in my humble opinion I think that is true for an SC or Carrera.
DANNOV
Old 01-29-2002, 07:57 PM
Eric Coffey's Avatar
Porsche Crest
Oh come on, live a little. Get a set of Jerry Woods' headers and mate them up to a pair of megaphones!
Old 01-30-2002, 12:37 AM
Buy them, sell them
Adam's Avatar
Well, I'm keen to make one of these up...
I'm now just looking for a Euro pre-muffler to butcher and modify. Image courtesy of Emcon5. He had one previously installed on his SC and said it sounded mean. He even posted an MP3 of it on a recent thread.
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 01-30-2002, 02:15 AM
Senior Member
Leland Pate's Avatar
I'm going to be attempting the "Flowmaster Special" conversion when I get home.
The parts are all waiting for me... and I only spent $170 for the muffler, two J pipes and a set of SS Borla tips..... we'll see...
Chief Architect and Mastermind,
SCWDP
Old 01-30-2002, 05:12 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Wink
You can always put a SCWDP sticker on your car. I hear it makes your car go faster. Since im no longer a lurker...i can say stuff like that.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 01-30-2002, 05:23 AM
Metal Guru
911nut's Avatar
Dannov, I couldn't agree more. There is one more way to peel this onion, though. I gutted my stock mufler and replaced the long internal pipe and packing with two baffles, maintaining the single outlet. Also I'm running a test pipe in place of the cat. I'll add a pre-muffler this spring only because it's still a little loud. At idle it sounds like a turbo and at 5000 rpm sounds like a serious race car.
Whatever you do, don't gut your cat and use it. It'll knock off about 10 HP. Also, don't buy SSIs unless you hit the lottery. In spite of what people say who have them, they don't provide hardly any more HP than a bypass pipe and a low restriction muffler (Bruce Anderson himself only measured 1/2 HP advantage between SSIs and a 2 in/2 out muffler vs a test pipe and a Performance Products sport muffler on a .32 Carrera).
Old 01-30-2002, 05:32 AM
Mikkel
Guest
Posts: n/a
Smile
Adam
You don't happen to have a link for that MP3 file do you?
Old 01-30-2002, 06:07 AM
At a DE event at Road America last year I met a guy who gutted his Carrera muffler and had a second tailpipe welded on to the right side. You could look into one tailpipe and see light from the other side. It was loud, LOUD! But he had a metal cap fabricated that fit over the right tail pipe for street use. That made a huge difference, it was still loud but acceptable for street use. However, it was about as far as anyone should go unless you like noise.
DANNOV
Old 01-30-2002, 06:18 AM
frz frz is offline
Lightbulb you boys are the bomb!
well i have to say you boys are chapter an verse
you are the bomb!
frz :>
Old 01-30-2002, 06:34 AM
mattd's Avatar
Does the "dual outlet" modification for the stock Carrera muffler require any internal changes? Or is it just cut and weld?
TIA
Matt
Matt Daniels
1975 911S
Old 01-30-2002, 07:10 AM
TIA
Matt
A new exhaust pipe is welded to right side, internals are unchanged. Sounds great, its cheap, and it adds a bit of power at 4000+ rpm. You have to cut the rear bumper valance for the new pipe, but that it is a small and easy job. The biggest problem for my mechanic was to find an exhaust pipe that matches the stock pipe on the left side. He got one that is identical to the stock pipe, it looks nice.
DANNOV
Old 01-30-2002, 07:24 AM
mattd's Avatar
Thanks Dannov, for the info.
Also - Mikkel - here is the link to that MP3:
http://www.pelicanparts.com/MotorCity/emcon5/911sc.MP3
Matt
Matt Daniels
1975 911S
Old 01-30-2002, 07:28 AM
mattd's Avatar
Hey Dannov,
Do you know where your mechanic ended up finding the pipe?
Matt
Matt Daniels
1975 911S
Old 01-30-2002, 07:30 AM
Hey Dannov,
Matt
I don't know, but he initially mentioned the possibility of salvaging a pipe off an old Porsche muffler. The pipe he put on looks like a new one and has the same up-turned edge as the stock pipe, a perfect match. He charged me $30 for the pipe itself.
DANNOV
Old 01-30-2002, 08:19 AM
Steve W's Avatar
I have to go with Dannov on this one. I ordered and am still waiting for the stainless 2 1/4 j pipe I ordered from jegs.com to show up so I can cut a section from it and have a right side tip TIG welded on. Then I'll slip on a stock black Porsche exhaust tip over it for a identical look. The 2 1/4 end will have to be swaged up to 2 3/8 to accept the tip. Here's the chart section of the B. Anderson article Dannov scanned me showing the hp similarities of ssi/w dual outlet muffler vs stock/w extra tip on 88 Carrera. Bottom graph is stock hp.
Old 01-30-2002, 08:52 AM
I have a dual-in/dual-out B&B muffler for sale, and I know someone who has the headers FS. That will get you some roar!
Old 01-30-2002, 11:06 AM
