JED
ARCSinAK's Avatar
Any drawbacks to installing Carrera sway bars on a SC
I have acquired a set of 87 sway bars for my SC, just curious if anyone else has made this change. Pros/cons, thoughts would be appreciated.
Regards-
JS
Old 01-05-2011, 03:22 PM
It's a common upgrade and a good one at that. Hard to find any cons. I guess if you had to nitpick you'd say that the torsion bars should be upgraded as well.
Old 01-05-2011, 03:38 PM
Banned
juanbenae's Avatar
you will need the bushing replaced as the bigger bars require different rubber bushings
Old 01-05-2011, 03:41 PM
RETIRED
Joe Bob's Avatar
One of my first upgrades.....
2012 ML350 3.0 Turbo Diesel
Old 01-05-2011, 03:58 PM
gtc gtc is offline
abides.
gtc's Avatar
The 22mm front bar can be a major PITA to fit into the a-arm bushings.
With the new G50 rear bar, check the clearance under the transmission crossmember after you install it. Mine was extremely close (but it does fit without rubbing).
It's a nice, but subtle, upgrade.
Graham
1984 Carrera Targa
Old 01-05-2011, 04:00 PM
Senior Member
Superman's Avatar
I have them on my SC. A good upgrade, IMO.
Mocha 1978 911SC. "Coco"
Old 01-05-2011, 04:11 PM
