BKC BKC is offline
Most stupid newb question ever?
Okay. There may be no such thing as a stupid question but there are stupid people who ask questions! So, here goes.
Could someone explain how the coolong system works on the 911sc? I see the fins on the cylinders. Is that the only cooling? What's with all the oil? I get that it's a dry sump with a tank and that oil is passed thru some sort of cooling device. (Trombone, Carrera fan oil cooler, etc.)
Then I see some hoods up and there's a radiator. I assume that's cooling oil? Is the fan drawing air in across that oil?
I guess there's no "coolant" but the fact the the oil is cooled allows for air to maintain tolerable temps?
I need a basic rundown of the relationship between all that oil and air cooling. I plan on buying an 80's 911 and don't want to be a complete doofis!
Old 01-12-2011, 05:27 PM
Driver
Noah930's Avatar
You've got air and oil as the two cooling media for old (pre-1999) 911s. No green liquid coolant.
Cooling fins on individual cylinder barrels: for air.
Oil and the front-mounted cooler: for oil.
You've pretty much got the basics right in your post.
1990 Black 964 C2 Targa
Old 01-12-2011, 05:31 PM
Wilhelm's Avatar
"Then I see some hoods up and there's a radiator. I assume that's cooling oil? Is the fan drawing air in across that oil?"
Perhaps the 911's you have seen with the "hoods up" with the "radiator" were Turbos? Was it the rear lid that was up? In that case the "radiator" is an intercooler to cool the compressed air from the turbocharger before it goes into the cylinders.
Old 01-12-2011, 05:35 PM
BKC BKC is offline
Oh. Yes it was attached to the hood with flex hose on either side.
Old 01-12-2011, 05:38 PM
Band.
What you saw was the rear condensor for the air conditioner. Cars with no A/C will (of course) not have them.
Don't worry about stupid questions!
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 01-12-2011, 05:39 PM
Checked out
McLovin's Avatar
he's probably looking at the AC condensor.
Old 01-12-2011, 05:40 PM
Oh Haha's Avatar
Actually, those are great questions. I'll do my best to help.
1. The fins on the cylinders help dissipate heat. The large fan located in the "front" forces air to flow over the engine, also to aid in cooling.
2. The oil system is designed to allow the oil to flow through the lines to a cooler, most times located in the front fender(s) in a high pressure area. Like a radiator, it cools the oil as it flows through and back to the engine. A thermostat controls the oil flow to the cooler based on the need for cooling.
3. On 911s with a/c, the condensor is located inside the tail or deck lid. Again, this is for air flow. On intercooled turbocharged 911s(the 930) the air to air intercooler is the other radiator type device located on top of the engine.
I'm sure some details were omitted but I hope this helps a little. Do some research and you will be an informed buyer and get the best 911 for the money. Remember, get a PPI before making any deals. PPI=Pre-purchase Inspection.
Pacific Blue
Wayne
Old 01-12-2011, 05:42 PM
Checked out
McLovin's Avatar
There's no such thing as stupid questions!
(Just ignorant people making inane inquiries).
Old 01-12-2011, 05:50 PM
BKC BKC is offline
Thanks for the info/clarification. I was so close last year to buying and then circumstances changed. Now I'm pretty close to back on track.
So, all that oil allows for a circulation loop that lubes and then gets cooled. The shear quantity provides time away from the heat created during lubrication. In other words, it doesn't really take 10 qts. of oil to lubricate the motor, it takes 10 qts of oil because you have to keep exchanging the heat out of it. (That's actually a question! )
Old 01-12-2011, 05:55 PM
BKC BKC is offline
Wouldn't "oil-cooled" be a more appropriate name or does the air provide the majority of the cooling and the cooled oil just helps out?
Old 01-12-2011, 05:58 PM
Wilhelm's Avatar
Right. Dont know why.... the first thing that came to mind was a Turbo
I havent owned a 911 with A/C in a long time ! Kinda forgot about that. Maybe we should mention here...dont expect it to put out as much cool A/C as a Crown Vic .
Old 01-12-2011, 06:01 PM
silver911rdb's Avatar
Let's not forget the primary oil cooler that bolted to the side of the engine case. The secondary oil cooler (radiator or trombone) is the one located in the front pass fender well.
-Rich-
1984 911 Track
1985 911 Track/Autocross
Old 01-12-2011, 06:24 PM
BKC BKC is offline
A primary? That makes sense. I was wondering how these little fender coolers could provide adequate cooling. How does it work?
Old 01-12-2011, 06:44 PM
muck-raker
kidrock's Avatar
Once the oil reaches a certain temperature (I believe somewhere in the neighborhood of approximately 200 degrees fahrenheit), the heated oil activates the auxiliary oil thermostat which is mounted above the right rear tire. The auxiliary then allows the oil to pass through on its way towards the secondary oil cooler, which is mounted in front of the right front wheel.
Once the oil has worked its way into the front (secondary) cooler, the oil is basically radiated throughout and is aided by 1) air which passes through a slit in the front bumper, and 2) a fan, if you have a Carrera or a Carrera fan upgrade.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 01-12-2011, 07:02 PM
Band.
Here: This is good for hours and hours of cool reading. You can search whole threads or just for specific words in the thread titles. Good stuff!
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
Old 01-12-2011, 07:06 PM
BKC BKC is offline
What about a primary?
Old 01-12-2011, 07:11 PM
muck-raker
kidrock's Avatar
primary oil cooler looks similar to a radiator, and is located on the lower portion of the engine on the right hand side near where the engine and tranny meet. Oil flows through this cooler at all times while the engine is running, then splits the cooling duties with the secondary cooler as oil temp reaches normal operating temps.
STONE
Old 01-12-2011, 07:38 PM
912 Geek
BKC:
You might consider buying a book on the technical aspects of the 911, possibly The Porsche 911 Story by Paul Frere. It's not a manual, rather a description of the technical history of the car. The Porsche 911 Buyer's Guide might also help you to find a good car.
Frank
Old 01-12-2011, 09:32 PM
HarryD's Avatar
Like the others said, you can do lots of reading. Ferre's book has lots of technical information. To help you a bit, below is a diagram of the oil system.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-12-2011, 11:46 PM
Halm's Avatar
Do not even think about buying a Porsche without PPI (pre-purchase inspection) by a highly competent mechanic. It will save you thousands of dollars and countless sleepless nights.
'17 Cayenne
Old 01-13-2011, 05:23 AM
