cattman's Avatar
Lit light and fog switch pulls?
I'd love to have some more light in the cabin. I've gone to new gauge bulbs, but I could use a bit more.
Specifically, one of the features I appreciate in modern cars are the illuminated window switches, as well as the pull switches for the headlights and fog lamps.
Does anyone know of a way to illuminate the door mounted window switches and dash-mounted headlight and fog lamp pull switches?
CATTMAN
2005 Porsche 911: 997S, supercharged to 530HP
1987 Porsche 911: Concours prep OEM guards red on black
Old 01-17-2011, 06:02 PM
Member 911 Anonymous
DRACO A5OG's Avatar
You could use "el wire" like a bead that can totally illuminate any area you wish but that will kill your Concours look. my 2 cents.
Nope, I do not have the Disco Effects
'85 Carrera Targa
PCA/POC
Old 01-17-2011, 08:39 PM
Formerly known as Syzygy
Canada Kev's Avatar
Your fog light switch should be lighted; the bulb is probably just burned out. You can pull out the plastic icon thing in the "handle" part by gently prying the rubber away and popping the plastic centre out with a small screw driver. The bulb just pulls straight out if I remember correctly. Pick up a replacement at your FLAPS.
You're out of luck with the headlight switch, unless you fab up something custom. Same with the window switches.
Not the best pic, but you can see they're lighted. They also get brighter when switched on.
Kevin
Old 01-17-2011, 09:06 PM
cattman's Avatar
Thanks, Kevin!
I had incorrectly assumed that it was unlit, a the headlamp switch. Odd that they are not BOTH lit, isn't it?
I pulled the cap off of the lighter, and there is no bulb behind it, so I assume it, too, is unlit- is that correct?
My car does not have the European rear fog lamp, but I may want to install the illuminated switch if only to provide more interior dash illumination- without even installing the rear fog itself!
CATTMAN
Old 01-18-2011, 02:02 PM
nineball's Avatar
my 83Sc does not have the rear fog but both my fog and defrost knobs light up when the lights are on, brighter once they are actually being used. the cig lighter does not light up.
headlights on
defrost knob pulled out
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 01-18-2011, 03:44 PM
Canada Kev's Avatar
His car won't have the defrost knob, I think. It should have the defrost button in the console like mine (again, not the best illustration of the lighting in the button):
Kevin
Old 01-18-2011, 08:03 PM
cattman's Avatar
Exactly.
But nineball, what is that round blue light in your photo?
Old 01-18-2011, 08:07 PM
schumicat's Avatar
it is probably aftermarket radio.
Originally Posted by cattman View Post
Exactly.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 01-18-2011, 08:51 PM
