Tired Member
DaddyGlenn's Avatar
Question How can I get the most out of my Parts Washer?
I have a 20 gal Harbor Freight Parts washer.
(mine is all red)
I currently use a diluted water based, biodegradable cleaning fluid. (the instructions say not to use a petrol based solvent)
This works alright but I'd like better, faster degreasing. Any recommendations on a better water based cleaning fluid or where I can find a replacement pump that will handle diesel or other solvents?
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 01-10-2011, 07:08 AM
RETIRED
Joe Bob's Avatar
Purple Stuff......
Old 01-10-2011, 07:42 AM
kodioneill's Avatar
I have the same one, I use standard parts solvent. I think they're tell you to use the other stuff cause it's GREEN. And of course it doesn't work well.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 01-10-2011, 10:40 AM
In maintenance phase
daniel911T's Avatar
simple green?
I''ve been very disappointed by the performance of the water solubile solvents. I actually was able to tear up some pretty serious grease with a spray bottle of simple green. I seem to remember people around here saying it hurts aluminum(?)
Anyway, SG is the only water based solvent I've come across that actually degreases at all.
-Dan
Old 01-10-2011, 10:45 AM
MAGA
Tim Hancock's Avatar
I have had one of those for 15 years and have always used mineral spirits that I buy in 5 gallon containers from an auto paint supply store. It works OK, but I am sure there are better more expensive solvents to be had.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 01-10-2011, 10:47 AM
I've always had a question about using water-based solvents in a metal tank. Any potential rusting issues? And the instructions suggest NOT to use oil-based solvents?
Sherwood
Old 01-10-2011, 11:01 AM
Senior Advisor
James Brown's Avatar
Simple green is corrosive to aluminum and other non ferrous parts and is banned by the military on aircraft. And yes, will rust ferrous metals. Dry cleaning solvent (PD-680) or a mineral spirits would be my choice of solvents.
08 Cayenne Turbo
Old 01-10-2011, 11:09 AM
Senior Member
Superman's Avatar
Kerosene works very well. Yes, I am kidding.
Mocha 1978 911SC. "Coco"
Old 01-10-2011, 11:21 AM
78 in a '71
mossguy's Avatar
Is there any special hazard using the mineral spirits with an electric pump? I am having the same issues with the water based "solvents".
Thanks,
Tom
On glide path......
1971 911 T Targa
2013 Ford Fusion Titanium AWD
Old 01-10-2011, 11:31 AM
You shouldn't be kidding. Kerosene works; has fairly low flash point and relatively inexpensive. PS: See correction below (#13)
Pumps designed to circulate cleaning solvent should be safe to use with solvent. However, confirm with the manufacturer to be on the safe side.
Sherwood
Old 01-10-2011, 11:53 AM
Tired Member
DaddyGlenn's Avatar
I was under the assumption that oil based solvents could eat through the pump on these inexpensive tanks.
Glenn
Old 01-10-2011, 12:00 PM
daniel911T's Avatar
A low flash point for a solvent is good?
Dan
Old 01-10-2011, 12:02 PM
Dan
Actually no, quite bad. Excuse my antonymic response. Replace with "high flash point".
Thanks for saving lives.
Sherwood
Old 01-10-2011, 12:08 PM
Senior Member
Superman's Avatar
Kerosene does in fact make an outstanding solvent, but I still wouldn't fill a solvent tank with it.
Old 01-10-2011, 12:33 PM
Pre-soak in diesel. Cheap, works, lasts a long time....
Old 01-10-2011, 12:35 PM
Targa Time's Avatar
I have the same parts cleaner as you do. In fact I had the same questions in this forum. (see Cleaning fluid) That being said, I started using Mineral Spirits as recommended by this forum.
It works fairly good, but you will still need to use some brake or carb cleaner on the stubborn spots. By the way Mineral Spirits wont harm the pump, and it is combustable not flammable. I just make sure to have some ventilation while using. I almost bought the same cleaner you have pictured. Until I read the caution label on the back that states it is damaging to aluminum.
Old 01-10-2011, 01:55 PM
fastfredracing's Avatar
******** Solvent is what you want to ask for. I have used it in my big parts washer, and my little washer ( just like yours) for years. No problems using it with the pump, at least I have not blown myself up yet. The stuff cleans great, and drys quickly. I get it at the local fuel oil company.
No left turn un stoned
Old 01-10-2011, 03:28 PM
ratpiper71T's Avatar
So does this type of parts washer (GLenn OP) have a holding tank to keep vapors from filling up your garage? Or do you have to drain it after every use? I'm thinking of buying one soon but not sure of how they store the solvent.
Mama lock your daughters up that wild bunch is back in town!...And them little girls get frisky when they hear that race-car sound!
Old 01-10-2011, 03:39 PM
Northern Motorhead
wildcat077's Avatar
Been using varsol in mine for the last 20 years with no explosion, our spray cleaner booths between the hangars at work use varsol as well and we haven't blown any aircrafts sky high yet ... lol
Guys,there is no danger whatsoever in using varsol in your parts cleaner,although i would keep the lid closed when welding nearby
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 01-10-2011, 03:51 PM
silver911rdb's Avatar
LPS makes a nice line of water based cleaners. I use LPS's Precision Clean Multi purpose cleaner/degreaser. It's sold in 1,5, & 55 gal containers and can be diluted with water or run straight. With any water based cleaner if you add heat they clean better. I use the above product in my heated parts washer and i like the way it works. It doesn't clean as quickly as safety clean but it does work well and is safer for you and the environment. You might want to add a heater element to your tank if you go the water based route. Maybe heat it up a few hours before you use it.
I'm an LPS distributor (among other lines) and have worked with their area rep and that's what he recommended as a cost effective cleaner for my parts washer. He also gave me a sample of T-91 cleaner. This stuff is supposed to be as effective as the solvent based cleaners but still non-solvent based and much safer. I haven't looked up the pricing on the T-91 but I think it might be on the pricier side. You can google these 2 products for more info. i hope this info helps you out.
-Rich-
1984 911 Track
1985 911 Track/Autocross
Old 01-10-2011, 04:14 PM
