I replaced my stock wheel with a 930S wheel from AJ USA.
There is a scraping noise when I turn the wheel. I applied dielectric grease to the horn contact and wiper. The noise goes away, but returns a month or less afterwards. It's definitely the steering column, and definitely in the wheel. Anyone have any ideas of what else might be causing this noise and/or eliminating it? Any thoughts appreciated! Don
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
I would honestly try replacing the column bushing. It's a simple pound-it-in replacement that cures most steering wheel ills with rough movement and the like. But if the dielectric grease *really* makes the grinding feel go away....
...try shaping the horn ring contact (the part on the car side, not the wheel contact) to be a little flatter. I did this and it fixed the problem for me.
Mark Szabo 1986 911 Targa 3.2 (I will miss you) 1985 Scirocco 8V (I will not miss you) 1986 Dodge B150 Ram Van (I can't believe I got $200 for you) 1987 Escort 5-speed 1.9 RIP |
If you do replace that bushing, don't replace it with another of the lousy plastic ones. There's a metal 928 bushing that is the preferred fix.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
I had this problem when I fitted a new wheel. It was the horn contact. I did what old_skul suggested.
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
Thanks for the suggestions guys - I'll try them this weekend.
Don |
