87 Carerra, 3.2 liter en
Help: Test Power to DME
I have done something dumb. I was hooking up wires to my headlights and foglights with no problem, all while starting the car to make sure I was hooking up the correct wires. I must have started the car 15 times throughout this process with absolutely no problem.
Then out of the blue the car stopped firing. I mean it keeps cranking without starting. I checked and I am not getting any spark to the coil whatsoever and the fuel pump is not coming on. I cannot hear it clicking on when the car is trying to start. I changed the coil as well as the dme relay. Still no spark to the engine and the fuel pump is not activated. I am now trying to troubleshoot. It is my understanding that I need to first check to see if I have power coming into the DME and then going out of the DME. Can anyone explain to me in simple terms how to do this. I have a 1987 carrera. I took the seat out of the car and I am prepared to test the power at the DME. I just do not know what pins to check or how to go about checking the power source to and from the DME Any help would be greatly appreciated. |
If you have a factory alarm system, it could be acting up. The power for your DME relay goes through the alarm brain.
LJ851:
Thanks for the reply. I ruled out the factory alarm. Years ago I disengaged the factory alarm and so it is inoperable |
Member 911 Anonymous
oh man, sound like the reference sensor.
get your DVM out and check the OHMs on both speed and reference sensor
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
muck-raker
Here's a very helpful thread on testing the DME unit, as well as the speed and reference sensors.
Another 84 Won't Start Quandry good luck, and please keep us posted.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Kidrock:
Thanks for the site. went to it and read it and it gave me the exact diagnostic check that I needed. |
