use of air/fuel ratio meters on carburated engines
Short of installing sensors in each of the 6 exhaust tubes, how can an air/fuel ratio sensor work if its installed in the single exhaust outlet?
rob
356robo
70 T Targa
Looking for a 2.2,2.4, or 89 coupe
Old 01-29-2011, 07:50 PM
Senior Advisor
James Brown's Avatar
It can, I have one on the left bank. Haven't hooked it up but it should get you in the ballpark. The car won't run very well if the a/f mixture is correct. Just not that accurate with carbs. And it will be rich at idle and lean at wot. It will drive you crazy trying to fix that!! But you can get close.
Old 01-29-2011, 09:29 PM
LJ851's Avatar
It works great for tuning everything but idle mixture. Assuming your carbs are in good working order and sync'd.
Old 01-29-2011, 09:52 PM
gumba's Avatar
One sensor in each heat exchanger by the flange, and a dual a/f gauge. I used 2 Innovate LC-1's to a custom Westach dual a/f gauge.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 01-30-2011, 07:17 AM
