Car not started in several years...what to do?
I have a '73 911T that has embarrassingly not been started in about 5 years. Engine was running well when parked, had a rebuilt MFI distributor 7 years ago. Brake hydraulics were shot though, had trouble bleeding out the fluid effectively back then even with a power bleeder.
The only preparation for this hibernation was siphoning out 3/4 of the fuel tank. Parked in an outside covered carport in central NC. Have some time to give it attention now and wondering where to start. Do I have to disconnect each part of the fuel system and flush, or can I fill up the tank with fresh gas and maybe some Swepco or RedLine fuel system cleaner? Should I bleed the brakes dry with the power bleeder and then start with new fluid? Any way to tell if the master cylinder needs replacing? Thanks!
Joel '73 911T -MFI- |
Almost Banned Once
The engine before trying to start it... Assuming your car has CIS.
1. Drain all fuel from the tank and put in fresh gas. 2. Replace oil filter and oil. 3. Replace Fuel filter and check air filter. 4. Check spark plugs and gaps. Replace if needed. (I would) 5. Check fuel lines for leaks especially around crimped connections. Look for cracked and perished rubber lines. 6. Make sure battery is fully charged. 7. Turn engine over for about 30 seconds with ignition system disabled. Pause for 30 seconds. (There are few different ways to do this. I do it by disabling the MSD ignition system in my car with the "kill Switch" anti theft option.) 8. Turn engine over for another 30 seconds with ignition system disabled. The reason you do this is to build up some oil pressure in the system before starting the engine for real. 9. Enable the ignition system. And then "miaow" the injection system... (You do this by lifting the air measuring plate while the ignition is on for about 10 to 15 seconds) CHECK FOR FUEL LEAKS AGAIN. 10. Then try and start the car for real. Have a slave battery handy. Brakes... 1. Remove all wheels after securely raising the car. 2. Bleed with power bleeder as normal. I wouldn't bleed them dry. Nothing to gain by doing so. Bleeding normally will flush old fluid anyway. If in doubt go around the car two times. You won't know the condition of the master cylinder until you get the car started and the brakes bled. Short drive and see how she stops. And take it from there. Good luck with getting her going. I'm sure she'll need her valves adjusted but first things first get her going and see how the engine sounds once warmed up properly.
- Peter |
Look for posts by Grady Clay on this topic.
This thread may be helpful to you: Winter storage checklist? Quote:
Thanks a lot Peter and Harry,
This was just the type of information I was hoping to find out, even if it's not what I wanted to hear. Grady's checklist sounds like many weekends of work, some beyond my expertise. I should clarify a few points. First, it is the MFI engine management system, not the CIS. Don't know if that makes a difference, although I've read here that the MFI distributor does not like to sit for a long time. In the 500 miles before the car started sitting, I did the following: 1. Changed oil and filter 2. Replaced fuel and air filter 3. Replaced rubber fuel lines (all were cracked and leaking!) 4. Added fire extinguisher and mount (see #3) 5. Replaced spark plugs 6. Adjusted valves So far I'm thinking I can handle: -fresh tank of high octane fuel with RedLine SI-1...change fuel filter after the first tank -replace oil to remove water/rust...change the "old" filter which has 500 miles on it after the first drive -battery is still good, amazingly (I've used it as a backup in my unreliable daily driver!) -crank engine w/o starting to circulate oil -attempt to flush brakes with new fluid -drive very gently through first tank, swap master cylinder and rubber brake lines if brakes are still bad Anything else I'm missing that it absolutely mandatory?
Joel '73 911T -MFI- Last edited by B'dole; 01-27-2011 at 08:47 AM.. |
Listen to Grady. He has forgotten more stuff than many remember.
At a minimum, I would also drain the fuel and replace and flush the fuel lines.
Only 73.5T had CIS. Don't know about Australia. Anyway, everything but your #9 is still valid - that's only CIS relative. As others said, do a search, Grady has actually talked about resurrecting an MFI car. Last edited by tcar; 01-27-2011 at 01:54 PM.. |
No worries, I updated my signature to make it clearer in the future which car I have.
Regarding #9, is there a way to "miaow" an MFI system? This sounds like a CIS-specific thing to prime a little fuel into the motor.
I'll see if I can find Grady's post... Edit: well I looked a bit, and there are a lot of posts. Don't have time right now to go through them. Try later. Last edited by tcar; 01-27-2011 at 02:22 PM.. |
After you drain the fuel tank remove the filter (screen) that's in the tank (outlet) and clean it.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
![]() When we bring a 911 out of long term (many years) storage, we drain out all the old fluids, pull the plugs, put in fresh fuel and....pre-lube the motor: We do this with an old oil pressure switch adapted to a 1/4in air line fitting and pressurized 5-gal paint bucket and 0W- or 5W- oil. With a regulator set at 35-40 lbs we fill the motor w 6 qts of oil in the case & put the rest in the tank. We then turn the motor over by hand a few times, then by the starter a few times, then fit fresh plugs & tune-up items as needed and run it. I do like Grady's suggestion of checking the bores for rust with a scope, though that means it must be turned over by hand a few times. Just like to be as cautious as possible w one of those very expensive motors. Len
B'dole
Bob, First Viagra and now Porsche, I knew you were one of us, How is it driving with the bad wing?
Apologies in advance.
Matt Cooley 1974 911 |
Sportomatic saves the day.
Well it took a few months but she came to life today, almost without a hiccup.
I did the following: -changed oil -drained gas -added Redline SI-1 -bled brakes thoroughly -installed a proper battery in the smuggler's box -wired a kill switch -replaced engine compartment fuel hoses and fuel breather hoses -re-installed charcoal canister (previous owner had disabled) Incredibly it started on the first try...did I mention it's been five years? Smoked out the exhaust for about 20 minutes, heavy at first then lighter, and now just a trickle. The brakes were ok at first, but then the pedal went almost to the floor after about 5 miles of neighborhood driving. Luckily I was ready. Since the brakes were well bled, is this the master cylinder? So good to be driving it again!
Could be but have you had a look around the car? The brake fluid could be leaking from anywhere. After five years without turning a wheel or changing brake fluid, it sounds like you've done well already . My thinking is a complete check up and replace of all brake seals would be in order...don't like the idea of not having the ability to slow down when I choose. Cheers
Detached Member
Congrats
I don't drive mine every week but I try to run it to operating temp at least once a week, same thing with my Honda generator which I load test with the wife's 1200 watt hair drier at least once a month for 15 minutes.
Hugh |
Good advice here for sure......One more thing about the brakes. Sounds like your m/c is questionable and should be replaced. When doing that, pull the flexible lines to each caliper and make sure they are not plugged. They swell from the inside, get totally blocked and don't allow the pistons in the caliper to retract......G'luck.
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Since you mention it, the wheels were very hard to turn by hand. I thought it was pad/rotor rust, but perhaps it's a blockage. Bled the system recently, and the fluid stream was weaker than other cars I've bled. Will check for leaks, too. Thanks for the help guys.
winter
I'd replace the master cylinder, rebuild the calipers and replace the brake lines and pads. Cool that the car started right up. Don't want to waste that by putting her into a tree when you can't stop!
Tom '76 Targa |
