Great, more compPetition looking for a good used black dash. Welcome! Nice ride. Jack |
VIN decode from the Dec. 1995 "genuine parts catalog 1974-89" page 123
1981-89 17 digit VIN code meanings WPO- 1,2,3 - 4,5 - 6 - 7 - 8 - 9 -10 - 11,12,13,14 WPO = W. Germany Porsche 1,2,3 = VDS Code *ZZZ refers to gray market vehicle. (*All chassis are stamped with ZZZ. Hoever the VDS code will be different on the VIN tag or title) 4,5 = Porsche type. 91 = 911, 93 = 930 6 = test digit 7 = model year. B = 1981, C = '82, D = '83, etc. up to K = '89. (I is skipped in this numbering system since I can be confused with the number 1) 8 = manufacturing location. S = Stuttgart 9 = 3rd digit of Porsche car type. 1 = 911, 0 = 930 10 = body & engine code. 2 = 911 coupe USA/Canada, 6 = 911 Targa USA/Canada, 7 = 911 Cabriolet USA/Canada 11, 12, 13, 14 = consectutive chassis production line serial number |
WP0ZZZ93ZFS000237
Is there a problem with the middle zero of the three zeros....? Shouldn't it be a 2, 6 or a 7 ? |
They sure have a way to make the exterior look spectacular ... I saw a segment on how BJ go about acquiring their vehicles.
Three guys show up at your door and basically pressure you to hand over the car for a ridiculous amont of money.I'm sure one of the guys who sold his car to BJ for next to nothing ended up jumping off a bridge when he saw how much they fetched for it ! Cheers ! Phil |
Alfonso....NOT a US car if the VIN truly is ZZZ.
Note to OP.....if you took the VIN number from the trunk floor, it WILL show ZZZ as the middle digits, but this will NOT be the VIN for a US-spec car...it will be the "chassis number". It IS the VIN for a Euro car. A US car will show VIN in these two other places - on the driver's A-pillar, with a riveted-on black number plate ( edge is rolled, I saw fakes with a "flat" black plate, no rolled edge. Beware !) - as you open the door, on the striker plate sheet metal under the latch. the trunk floor numbers will match BEFORE and AFTER the floor's ZZZ numbers.....but will have other characters like... AP0 instead of ZZZ. A sticker. |
Probably no way to know the exact miles if the speedo has been changed over to one that reads in MPH. The front flat fenders are not factory since they dont have the vents in them so its pretty safe to assume they didnt use factory parts in the conversion. This is a chop top cab that didnt start life as a cab so its value really depends on the inner workmanship of the conversion. A PPI would have been nice on the motor to see what the leak down and compression numbers looked like and give you at least some idea of how the motor is.
Sort of a crap shoot, nice looking car if you like slant cabs could be a 10 bell winner or not hard to say on the given info. |
Well, If the motor and trans are orig, you have a 300 HP Euro Turbo with a 40% LSD. Thats a good start. IMO its a shame that its not a coupe any longer.
We don't even need the VIN to know it cannot be a US turbo. 930's didn't return to the US until model year 86.
I don't care for slant nose turbos but that one sure has nice paint! |
porschenut....good call....correct, no US Turbos until their re-introduction in '86. Since we haven't established how much was done aftermarket or not ( slope-nose, etc)....I also didn't want to assume the turbo was factory either.
Started life as a 930 sunroof coupe. There were no factory slants in 85, but some special wishes cars done in Germany. However, they normally used Targa's for conversion to convertibles, not coupes.. Also the fenders do not appear to be normal steel conversions with vents. the headlights would lend further info. Special wishes coul have done most anything to customer spec though in 85. Even if not done at factory direction, It could still be a good job, but would require significant strengthening to prevent cowl shake under hard acceleration with 930 engine.
All that being said there are two option codes that weren't explained. I330, I391 Model year: 1985 Model ID: 911 Engine Code KW HP Liter Cylinders Model 930.66 221 300 3,30 6 911 TURBO Transmission Code: 930.36 Options found on your vehicle. Option Code Description M058 Impact absorbers, front and rear M197 Stronger battery M220 Locking differential 40 % M261 Door mirror - flat - passenger's side, electrically adjustable and heatable M533 Anti-theft device M650 Electrical sliding roof The following codes were found, but the description may not be accurate. Option Code Possible Description M567 Windscreen tinted, upper part darker coloured We were not able to find definitions for any codes below this line. I330 I391 |
BTW, thanks for posting.I watched this car across the block and wondered what the story was. I'm afflicted by the slant bug and would have tried to buy the car if I had been there.
http://forums.pelicanparts.com/uploa...1295798208.jpg |
Definitely not Porsche
Wow man, $30K+ for a chopped up coupe? That's rough.
That's clearly not factory slantnose stuff, but hopefully it's at least steel (not fiberglass). And hopefully they did at least some kind of stiffening to the chassis. The coupe was not designed to have the roof cut off. If they just chopped the roof off and called it a day, that car is going to drive like a wet noodle. Given the history of the car (Euro import, swapped speedo, chopped up, etc.) the number on the odometer is meaningless. Hope it works out for you (steel conversion parts, decent quality conversion, not too worn out mechanicals, etc.) An auction was the perfect place to sell that car, it does look shiny and in any situation where there is due diligence and full disclosure made on the car, it is going to be a very tough sell. |
As others have told you, this is a car that started life as a Euro turbo coupe, and had its top taken off to be made into a cab. The "factory" way to have done it would to have added some chassis stiffening braces to minimize the structural loss of the roof. There were no turbos imported into America in 1985.
Still not clear if it's a factory "special wishes" slantnose or not. 1985 would not have been a year that the slantnose option was official. But if you paid the factory enough, they could make anything you wanted. By far, chances are this was not a factory slantnose. But if factory parts were used for the conversion, at least you'd find: front and rear quarters should be steel. Stamped steel, not welded in the rear. Not fiberglass. Most front fenders had louvers above the wheelwells, but there are some early factory slants that did not. The front headlamps (which don't look Porsche, BTW), should be powered by a single motor with a rod connecting the two mechanisms. Not two separate motors. The boxed rocker panels should have a working jackpad receptacle extension roughly midships (so that you can jack up the car). The rear fender slats (3 per side) should be made out of wood. There should be a front center-mounted oil cooler. There should be a cooler in one of the rear fender intakes, as well. Those are the factory slant details off the top of my head, at least. Do you have a picture of the options sticker affixed to the underside of the front hood/bonnet? Whether it's "real" or not, enjoy your car. |
Thanks for all the replys.
Here is what I know: - the VIN is good. That is unless there has been a 25 yr mistake/scam. I have the registration records back to 1985 when the car was first registered in the US in Edna, TX. - the mileage is probably correct. With most of it's 12 previous registrations the mileage was reported and does not appear to be out of place/sync. I suppose there could be something amiss, but I doubt it. - since the vehicle has not yet been delivered and I did not not check, I don't know about the fenders. But I do recall a fiberglass hood. - no accidents or damage reported to Carfax. Of course this data is only as good as the reporting. |
There should be a sticker on the underside of the front hood. It'll list the options that came with the car. Of course, if the hood is fiberglass it's not original so who knows what happened to that sticker. Easiest way to get the above info, at least.
If you're so inclined, you can pay about $100 and order a Certificate of Authenticity (COA) from Porsche based upon your VIN. They run them in batches, so you might get it in a few weeks...or it might take several months. It should list the same essential info. Accuracy is suspect, though. There are reports that the COAs people have received have clearly been wrong, in which case another attempt (or 3) had to be made to get the correct info listed. |
| All times are GMT -8. The time now is 02:01 PM. |
