Carrera brake booster diagnostics
Hi all,
My '85 Carrera pretty much feels like it has manual brakes: Firm pedal, limited travel, and it takes some serious leg to get it to stop. I'm suspecting something in the brake booster, so I started testing a few things. Here's what I've found...
Any thoughts on my questions in item 4 above? I'm thinking I have a faulty booster. Which begs the question: Does anybody rebuild these, or must I purchase a new one? Thanks!
Curtis 1985 RoW Carrera Targa |
Welcome to Karps Brake Service
KARP'S Power Brakes 66 N. Central Avenue Upland, CA 91786 Phone - 909.985.0800 Fax 909.985.5120 karps@resleeve.com
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
After not driving my '80SC for almost 2 yrs, I took it out for a ride and had the precise braking problem you have! Bled brakes, checked for stuck calipers, etc, etc! In the end I put in a really nice booster and MC unit that I scored off Ebay, and now it brakes like new again. I had done most, but not all of the vacuum tests you did and didn't find anything that appeared to be wrong! Had me baffled, but the replacement booster was the fix.
You might check Ebay, as a lot of the "dismantlers" have good used booster/MC units available from time to time. Got mine for less than $100. Good luck!
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
So, I finally headed uwanna's advice and picked up a known good booster/MC. Testing it off the car, it behaves just like my current booster.
![]() The fact that uwanna's replacement booster seemed to test the same as his original one but still resolved his issue gives me hope. But I'm also confused about what the issue could be, and am a bit hesitant to go through the work of swapping them out. I'm curious - is it possible that my car pulls a good 16-19" of vacuum at idle at the booster nipple, but has a leak that only comes into play when the booster actually needs vacuum? I my mind, vacuum is vacuum is vacuum, such that any leaks in my system would prevent it from pulling proper vacuum on the Mityvac. BTW, I inspected the vacuum line that runs from the left rear of the engine, down around the rear t-bar tube and into the tub. It looks great - no signs of dryness or cracking. Thanks,
abit off center
You did pop the line off at the booster after running it? it should still have a vac for a good amount of time. It should operate just fine at around 15 so if your pulling that much and its holding it must be something in the booster but other than a leak which you can test after the engine is off I don't know what it could be.
Does the car pull when your brake? collapsed rubber brake line maybe if it does? If you hold the brake on then start the car you should feel the pedal go down a bit.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. Last edited by cgarr; 04-07-2011 at 04:30 PM.. |
Try comparing the vacuum at the booster vs the vacuum at the T joint immediately behind the cruise control servo in the engine compartment. I didn't have a gauge to test for actual numbers, but what I was drawing in the bonnet was a fraction of what I was drawing at that T connection. When I hooked it back up I must have cleared an obstruction in the vacuum hose between the T and the center well line - instant vacuum assisted braking (after I'd already sourced the booster through ebay). Difference was incredible. Net, net - check that section of hose in the engine compartment first - it seems to be a frequent failure point in the system.
Good luck. |
So put me on a highway
Resolved?
cwitt, did you get it fixed? I have similar problems.
1985 911 Euro Cab. |
| Tags |
| test brake booster |
