82 SC engine noise....
Ok so I have read all the posts that popped up regarding Anything remotely close to what I have experienced. Unfortunately I feel even more confused than before!
The issue: My SC (engine was rebuilt alittle over 15k ago, prior to my caretaking including updated tensioners) has been making almost a rhythmatic thumping noise that appears to be coming from the left side, when seated in the drivers seat. Now, this only occurs once the car has warmed up and been run for 10-15 minutes, no unusual noises or sound prior to this. I have not experienced any loss of power, exhaust smoking (other than the occasional on start up when it has sat for a while) or any other telltale signs of engine issues. Any ideas? Thanks Brian Last edited by brol; 02-06-2011 at 05:15 PM.. Reason: Spelling |
I'm here to cause trouble
Does this occur at all RPMs, and does the frequency of the thumping increase and decrease with a change in engine speed? Do you hear it whether stationary or in motion? Can you feel it or just hear it?
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP) '90 Miata LeMons Contender! '71 Datsun 510 (RIP) '67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP) '62 Plymouth Valiant '60 Ford Galaxy 500 (RIP) |
The only time I can say I absolutely can hear it, is when the car is stationary at idle. I have considered it may also be when the car is rev'd however I have not been able to pick it up on accel/decel, and I have definitely not heard it in motion either. Thanks Last edited by brol; 02-06-2011 at 06:26 PM.. |
Hmmm... at idle, does the noise seem worse when the clutch is in or out? Or no difference?
Thanks |
Again any help appreciated! Thanks Brian |
When idling and the rear deck open can you pinpoint the source more closely?
FWIW, the Carrera tensioners can and do fail. Is it coming from the left chain case? (Get a 2' long piece of garden hose; one end to your ear, move the other end around the engine.) Voila', a stethoscope. Last edited by tcar; 02-09-2011 at 03:05 PM.. |
Will do, thanks! I will report back in a few days and hopefully have more to work with.....
Keen 915 operator
I too can sometimes hear a slight thumping noise from my engine ('82 Euro SC). Usually barely audible, but I can hear it at low RPMs when driving next to an object which allows the sound to reverb (for instance a wall). It can also be heard on the overrun. Since this is my first 911, I was puzzled and somewhat worried the first time I heard it, but when I'd calmed down a bit I began thinking logically about it.
In my case, the sound isn't very intrusive, it's not a harsh, metallic sound (such as a chain rattling) and it hasn't gotten worse over the months I've had the car. The engine pulls strongly, too. I'm not sure as to how used you are to old air-cooled 911s, but there is quite a bit to get used to, not least sound-wise. This has to do with a few things, mainly that the engine is in the rear (duh!), making the exhaust system relatively short. Also, the engine is air-cooled (double duh!), which means that there is no water running around the engine, which in a normal car serves as sound insulation. So it's possible the sound we're hearing (given it's the same sound) is perfectly normal, and that the people who've been involved in 911s for donkeys years are so used to it that they simply can't hear it any more. It's just part of the car's charm. Having said that, if the sound becomes worse and/or the engine starts to act strangely, it's a cause for further inspection. Just my proverbial $.02
/Felix '82 Porsche 911 SC Coupe '77 Porsche 924 Targa Instagram: @orebro.classics | @924.resurrection |
As felix said, these are not quiet/ smooth engines at idle, is it possible you are not used to the sound of a 911 at idle? To most non Porsche people, my car at idle doesn't sound wonderful.... lot's of character however. When I hear other 911's at idle though, they're all quite similar. Maybe you should do a sound check with another in your area. Cheers
Thanks, I had a friend listen to it the other day, He said he thinks its a valve that needs adjustment. I would never had placed it as that being the sound I am hearing, but taking into consideration the above posts it make sense
Thanks! |
at 15k miles after the engine rebuild, it is time for a valve adjusment ...
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
The PO stated he had recently done one prior to my purchasing it. However I cant verify it was done (or right for that matter). SO its now on the list! Thanks for the input.
