Jupiter 911
bklyn's Avatar
Zinc additive, which one?
Last week I posted that for some reason it was getting harder to find Brad Penn oil in my area. So if I do not mail order it and use, lets say Castrol 20-50 what would be a good zinc additive that is not snake oil?
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 02-13-2011, 06:15 AM
Free minder
Aurel's Avatar
There are other choices of oil with ZDDP. I use Kendall GT1 from Autozone for example.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 02-13-2011, 06:28 AM
Bill Verburg's Avatar
Here are Kendalls specs for their Gt1 oils
T-1® High Performance Motor Oil
Typical Properties
SAE Grade 10W-40 20W-50
Density, g/cm3 @ 15.6°C (60°F) 0.873 0.883
Density, lbs/gal @ 15.6°C (60°F) 7.27 7.35
Color, ASTM D1500 3.0 3.5
Flash Point (COC), °C (°F) 227 (441) 230 (446)
Pour Point, °C (°F) -33 (-27) -30 (-22)
Viscosity,
cSt @ 40°C 108 175
cSt @ 100°C 15.3 18.6
SUS @ 100°F 559 913
SUS @ 210°F 81.9 94.9
Viscosity Index 150 120
Cold Cranking Viscosity, cP 6,600 6,600
@ (°C) (-25) (-15)
High-Temp/High-Shear Viscosity, cP @ 150°C 3.9 4.8
Sulfated Ash, ASTM D874, wt % 0.94 0.98
Total Base Number (TBN), ASTM D2896 7.8 7.8
Phosphorus, wt % 0.077 0.108
Zinc, wt % 0.085 0.119
translation for 10w-50 phosphorus 1080ppm, zinc 1190ppm
as noted previously oils that do not have to meet ILSAC GF-4 standards will have more of these 2 ingredients
there are others for instance in Mobil 1 the zinc & phosphorus content is in the range of 0.12 - 0.13 weight percent (1200 - 1300 ppm)
M1 product guide
if you want really high levels of zinc/phosphorus you would need to use a racing oil, M1 racing is 1750-1850 ppm Swepco, Brad Penn, Joe Gibbs have similar racing products.
there are all sorts of additives from Eastwood to STP , but using an acceptable base oil is best, in the 110ppm range is generally considered adequate
Bill Verburg
Old 02-13-2011, 07:57 AM
DanielDudley's Avatar
Several 911 mechanics are passionately against Castrol on this board.
Valvoline VR1 racing is also a good oil with decent ZDDP levels.
Old 02-13-2011, 08:20 AM
This is one of the best if not the best... It's also the only one I've seen that's made with synthetic oil and thats a good in a hot turbo.
Accordding to the specs on the webpage half a bottle mixed with 12 quarts of Valvoline VR1 would give you around the same amount of zddp as Brad Penn racing oil.
Red Line Synthetic Oil - Motor Oil for Racing - Engine Oil Break-In Additive
Old 02-13-2011, 08:32 AM
nineball's Avatar
i second that. last year it was on sale for 50% off and now i have 7 cases sitting in the garage
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 02-13-2011, 11:50 AM
NAPA here has ZDDP additive. Use w/ Mobil 1.
...or Christopher Hitchens on Stieg Larsson | Culture | Vanity Fair
you need 2 bottles per oil change.
You can also get Brad Penn on ebay pretty reasonably.
Old 02-13-2011, 01:04 PM
Jupiter 911
bklyn's Avatar
Thanks for the new ideas, found Brad Penn on e-bay, not a bad price but shipping is a killer.
Old 02-13-2011, 01:33 PM
I've looked at all the oil brands mentioned and they are all SM, I thought this grade was low on ZDDP. The higher weight oils still say SM even though supposedly the low ZN and P are only req'd for lower weight oils? After all the reading, still not really sure what to buy! IS GF-4 the real designation to look for?
I have some Joe Gibbs (expensive) and 'Kenwood' that I found at a local mini chain (Benny's) that is SL.
Sorry in advance if this is a hijack or re-hash. I have to feed a 911, MGB, 944 and 6cyl Bronco.
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 02-13-2011, 01:43 PM
Canyon Runner
70SC's Avatar
Porsche Crest Brad Penn
Just changed out my oil from Castrol GTX 20/50 to Brad Penn 20/50 Car is smoother with less valve train noise . B P is getting harder to find , But IMHO is definitely worth it !!!!!!!! My car didn't like the Castrol , It's much happier with it's fresh blood . And NO need to mess with expensive additives . BP Rocks
Old 02-13-2011, 03:42 PM
HarryD's Avatar
For those looking to doctor a lesser oil, I have 5 bottles of the old GM EOS that I would be willing to part with. E-mail me and we can make a deal.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-13-2011, 04:15 PM
