Question 930 Calipers on SC
I managed to pick up a nice set of 930 front & rear Calipers for my SC Race Car... Is there anything else I require to upgrade on the car... what are my best options for a slotted or drilled (floating) front rotor and a slotted or drilled rear rotor (bearing in mind I am in UK)... Many Thanks and your help is much appreciated. Steven
Steve at Rennsport can answer all your questions. I do know the either the fronts or rears need to be machined and you need a different hat for the fronts.
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
Steven - See this link for all the info you will need. I had these guys do the machining for me on the rear calipers and supply the front rotors & hats, 23mm MC and the new hardlines etc... Steve at Rennsport would be another fantastic source.
930 Brake Upgrade 911 - Carrera - 914 - 914/6 Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
the front rotor should be a 304x32 to 309x32, there are several options 1) oem hat & annulus from a '78 -80 930 2) Colman 4) Willwood 5) Brembo hat and and annulus from someone like Pro-Systems One of 2 or 4 can be purchased w/ a hat from VCI. I would get plain or slotted nit drilled the rear caliper needs to be modified from 3.5" axial mount to 3" axial mount, VCI can do this too. I'm sure that there are also places in the UK that can help too
Just reading through everything... thanks all for replies
Think about going to a bigger MC too -23mm.
911S/GTS4 964 C4 1987 Carrera 3.2 |
