Kyle (guest)
Guest
Posts: n/a
Wayne,
I have an opportunity to pickup a 88' 930. What are the differences in the removal proceedure? The motor has low mileage but has been sitting for a number of years. What should I check/replace i.e. seals, brakes etc.? Good stuff in the article! Kyle
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: 911 Engine Removal Made Easy
Old 02-08-2011, 10:53 PM
Author of "101 Projects"
Wayne 962's Avatar
The main difference is the exhaust and turbo plumbing that you need to remove. Nearly everything else is very similar. The fuel injection in the engine compartment is similar, but more complicated. Take photos of everything (hundreds of photos) just in case you miss anything. For the stuff that I recommend replacing, see my Engine Rebuild book, http://www.101projects.com
- Wayne
