Eddyvdw's Avatar
iPod connect to vintage radio
Guys,
Wanted to connect my iPod to my Blaupunkt radio MY 72. Found this thread at Samba and it works brilliantly!
TheSamba.com :: View topic - Step by Step Guide To Making Din to iPod connection
Now I only have to pick the right music to complement the sound of my 2.4E.
Cheers,
Ed
72 911E Targa (fun car)
BMW 535i Xdrive (work car)
Volvo XC90 Ocean Race (family car)
VW T2 Riviera Camper van
Old 02-14-2011, 01:18 PM
MH911's Avatar
Hmm, 72. How about some Bachman Turner Overdrive or Robin Trower?
Of course this would be on 8 track.
Kipp
1987 Black 911 3.2 Carrera Coupe
1999 Green Mazda MX5 (SOLD)
Old 02-14-2011, 02:37 PM
nineball's Avatar
using something like this is much easier. the wired versions don't have the problems that wireless ones do.
** Wired Universal Fm Modulator (With Gain Control) - Generic - metalfmodulatoraux
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 02-14-2011, 03:04 PM
rnln's Avatar
Does anyone know a way to use an ipod without using the head unit?
Fat butt 911, 1987
Old 02-14-2011, 03:20 PM
nineball's Avatar
you can run the ipod outs via a 1/8" to rca patch cable directly into most aftermarket amps but it's not a good thing to do. that setup can easily harm an amp due to the output voltage being too high OR too low (dependent on the amp being used). some amps have very low input sensitivity and others require more. it's not impossible, just not something i would suggest doing.
if stealth is your goal you can always mount an aftermarket hu in the glovebox or under a seat and connect your ipod to that.
Old 02-14-2011, 03:24 PM
Senior Advisor
James Brown's Avatar
Yes, I have just a 500W 4-channel amp with the RCA inputs to my iphone (or ipad/ipod, ianything). works great and doubles as a hands free phone. There is a blank-off plate where the radio was and the plug runes under the center carpet. A little velcro on the phone and the plate holds it in place.
08 Cayenne Turbo
Old 02-14-2011, 03:32 PM
Do our stock 1972 Blaupunks have a DIN input? How is it controlled?
1972 911T/S MFI Survivor
Old 02-14-2011, 03:58 PM
rnln's Avatar
If that is the case, then what will happen? Burn the amps?
Fat butt 911, 1987
Old 02-14-2011, 05:23 PM
rnln's Avatar
Nine ball, james,
I have 3 amps. 1 amp for subs, and 2 are for front and rear speakers, I assume. In that case, I need to devide the single plug form the ipod to at least 6 RCA. Correct?
This system won't be able to tell which channel is which channel. It will just push out the same frequency to all channels. Correct? Does this make the sound bad?
Fat butt 911, 1987
Old 02-14-2011, 05:28 PM
nineball's Avatar
if the amp needs more input then you will have greatly reduced output from the amp. this usually leads to people cranking up the gains on the amp, which will send a clipped signal to the speaker. this can damage both the amp and the speaker.
if the input it too high for the amp you can easily fry the internals. once the magic smoke is released the amp will no longer work.
Nine ball, james,
i have never seen a 1/8" or ipod cable that goes from 1 input to 6 outputs, nor will i ever. that's not to say that someone couldn't make their own using a lot of "Y" patch cables but i certainly wouldn't do it. another possible solution is equipment dictated. some amps have a pass through output for patching the signal to the next amp. if 2 of your 3 amps have this feature you can do that.
if you are using the hu to control the crossover points then yes, it will feed a full range signal to everything. if the amp has crossovers and they are being used then no.
the piece i linked earlier is really the easiest way there is to add an aux-in to any car radio. it goes inline with your antennae directly at the radio and gives you a set of rca style inputs, connect the positive and ground wires and that's it. nothing else to do, nothing else to modify and you can easily take it out and install it in your next car if needed. works with every media player on the planet that has a headphone jack
Old 02-14-2011, 05:44 PM
RETIRED
Joe Bob's Avatar
Woody's who sells on eBay, remakes vintage radios with modern guts and iPod connectors. They are very reasonable. They will also make a particular model to your specs. I put one in a 58 356 that I re-did.
2012 ML350 3.0 Turbo Diesel
Old 02-14-2011, 05:57 PM
Senior Advisor
I use 2 Y connectors and set the gain to balance if you will front to rear. Still have stereo just not adjustable front to rear. That's fine, like to hear the engine most of the time but on long trips music helps.
08 Cayenne Turbo
Old 02-14-2011, 08:46 PM
