Quick question
This should be easy for you guys. Is the dash in a late eighties carrera the same as a 964? I bought a 964 dash for my 84 and need the defrost trim piece. I just wanted to make sure if I bought the defrost trim from a late eighties it would fit the 964 dash.
Thanks in advance. Steve
Steve 69 911e |
As far as I know the design of the dash changed 1986. Not sure if you can make a post-86 dash fit a car from 1984. Maybe someone else can chime in.
/Johan
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
You are correct, it changed in 86.
1984 911 Coupe 2007 Z4 M Coupe 2008 Cayman S 2004 M3-Alpine White(sold) 2002 M Roadster (sold) |
Thanks for the help guys. I have actually put the 964 dash in my 84...with some metal cutting and hole drilling. I now need to get the defrost trim piece to complete the dash. I just want to check that if I buy one from a post 86 carrera, it will match up with my 964 dash.
Steve 69 911e |
