-   -   Fuchs, DIY stripping question (http://forums.pelicanparts.com/porsche-911-technical-forum/591632-fuchs-diy-stripping-question.html)
Joe Bob 02-14-2011 10:22 AM
Economics being the way it is, I'm doing my first DIY Fuchs polish.
MOST Fuchs have cooperated and given up the paint with oven cleaner and/or stripper. I have a pair that is being uncooperative. I've gotten them down to about 20% left.
What grade steel wool or sand paper will finish the removal but leave the least amount of scratches?
TIA
zippy_gg 02-14-2011 10:40 AM
I'd like to see you results as I am about to embark on the same jorney...
http://forums.pelicanparts.com/uploa...1297708765.jpg
I want to remove the old black paint and get a nice polish look instead.
Joe Bob 02-14-2011 10:43 AM
I usually just send them out to Al Reed. I'm sure I'm not the only one on this board who is trying to save a buck.....
jeffery dalcour 02-14-2011 01:56 PM
Joe Bob, I'd wouldn't recommend steel wool or sand paper. Both would be to ruff and leave scratches. Try to find find rubbing compound or jewelers polishing compound and use a cloth polishing wheel on a electric drill. The compound come in various grit sizes lower numbers being coarser (use these to remove residual paint) high grit levels are for polishing.
Waxing or clear coating after polishing will give you a long lasting mirror finish.
Hope this helps.
Jeff
P.S. it's a good idea to clean your wheel often. This is done by running the drill or grinder over a rough surface or edge of a work bench. Just be careful of kickback from the drill.
James Brown 02-14-2011 02:04 PM
[QUOTE=P.S. it's a good idea to clean your wheel often. This is done by running the drill or grinder over a rough surface or edge of a work bench. Just be careful of kickback from the drill.[/QUOTE]
Took me a little while to figure this out, your talking about the polishing pad on the drill or grinder. Joe, there are tons of threads on just that here.
ppanagis@gmail. 02-14-2011 02:10 PM
Aircraft paint stripper would get 90% of the paint off and the rest was done using a drill with small 3m scotch bright pad. if your going to repaint all black centers just wondering why you would want to remove 100% of the paint?
http://forums.pelicanparts.com/uploa...1297721328.jpg
Joe Bob 02-14-2011 02:12 PM
Gonna do a full polish.....
ppanagis@gmail. 02-14-2011 02:14 PM
have you tried Aircraft grade paint stripper?
DW SD 02-14-2011 02:21 PM
Joe,
Don't use steel wool. It can embed in Aluminum and later rust.
Joe Bob 02-14-2011 03:53 PM
Going to throw another 15 bucks at them for Aircraft Stripper. Found an automotive paint store that carries it.......the guy said that even though it's called Aircraft Stripper, it's not recommended for aircraft. Go figure....
zippy_gg 02-14-2011 04:14 PM
I always figured an aircraft stripper would be helpful in joining the mile-high club! :cool:
Now looking for a local automotive paint supplier...
gtc 02-14-2011 04:47 PM
I have a wire brush dremel bit that does a good job of removing paint that is stuck deep in the recesses of the wheels, but is gentle on the aluminum.
Joe Bob 02-14-2011 04:56 PM
Got a pic of the wire brush Dremel attachment? Or better yet the part#? Take a look here.....any of these?
Dremel Wire and Bristle Brushes, Dremel Cut Off Wheels 1/8 Inch Shank
coxy 02-15-2011 02:43 AM
Here you go
My Porsche 911 | Wheels and Tyres
Mikey37027 02-15-2011 05:57 AM
I would try the oven cleaner again w/ a plastic scraper, then 600 wet sand, 1000 wet sand then buff-out...
chamilun 02-15-2011 06:33 AM
you might try gasket remover as mentioned below:
Removing Powder Coating Quickly and Cheaply -- Chopper Surplus
Joe Bob 02-15-2011 09:53 AM
coxy......nice write up. How were your fingers afterward? Mine tend to lock up, double joint kinda. Not looking forward to that.
Arizona 911 02-15-2011 07:24 PM
I want to paint the centers of my wheels black like zippy gg'shttp://forums.pelicanparts.com/uploa...1297826611.jpg
kidrock 02-16-2011 03:22 AM
Hey Joe Bob,
howzabout some before and after pics? :)
Joe Bob 02-16-2011 08:25 AM
http://forums.pelicanparts.com/uploa...1297873506.jpg
