RETIRED
Joe Bob's Avatar
Fuchs, DIY stripping question
Economics being the way it is, I'm doing my first DIY Fuchs polish.
MOST Fuchs have cooperated and given up the paint with oven cleaner and/or stripper. I have a pair that is being uncooperative. I've gotten them down to about 20% left.
What grade steel wool or sand paper will finish the removal but leave the least amount of scratches?
TIA
2012 ML350 3.0 Turbo Diesel
Old 02-14-2011, 10:22 AM
French Import
zippy_gg's Avatar
I'd like to see you results as I am about to embark on the same jorney...
I want to remove the old black paint and get a nice polish look instead.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 02-14-2011, 10:40 AM
RETIRED
Joe Bob's Avatar
I usually just send them out to Al Reed. I'm sure I'm not the only one on this board who is trying to save a buck.....
Old 02-14-2011, 10:43 AM
Joe Bob, I'd wouldn't recommend steel wool or sand paper. Both would be to ruff and leave scratches. Try to find find rubbing compound or jewelers polishing compound and use a cloth polishing wheel on a electric drill. The compound come in various grit sizes lower numbers being coarser (use these to remove residual paint) high grit levels are for polishing.
Waxing or clear coating after polishing will give you a long lasting mirror finish.
Hope this helps.
Jeff
P.S. it's a good idea to clean your wheel often. This is done by running the drill or grinder over a rough surface or edge of a work bench. Just be careful of kickback from the drill.
Old 02-14-2011, 01:56 PM
Senior Advisor
James Brown's Avatar
[QUOTE=P.S. it's a good idea to clean your wheel often. This is done by running the drill or grinder over a rough surface or edge of a work bench. Just be careful of kickback from the drill.[/QUOTE]
Took me a little while to figure this out, your talking about the polishing pad on the drill or grinder. Joe, there are tons of threads on just that here.
08 Cayenne Turbo
Old 02-14-2011, 02:04 PM
1969 912 (2.4l 1973.5)
ppanagis@gmail.'s Avatar
Send a message via Skype™ to ppanagis@gmail.
Aircraft paint stripper would get 90% of the paint off and the rest was done using a drill with small 3m scotch bright pad. if your going to repaint all black centers just wondering why you would want to remove 100% of the paint?
Old 02-14-2011, 02:10 PM
RETIRED
Joe Bob's Avatar
Gonna do a full polish.....
Old 02-14-2011, 02:12 PM
have you tried Aircraft grade paint stripper?
Old 02-14-2011, 02:14 PM
DW SD's Avatar
Joe,
Don't use steel wool. It can embed in Aluminum and later rust.
1971 RSR - interpretation
Old 02-14-2011, 02:21 PM
RETIRED
Joe Bob's Avatar
Going to throw another 15 bucks at them for Aircraft Stripper. Found an automotive paint store that carries it.......the guy said that even though it's called Aircraft Stripper, it's not recommended for aircraft. Go figure....
Old 02-14-2011, 03:53 PM
French Import
zippy_gg's Avatar
I always figured an aircraft stripper would be helpful in joining the mile-high club!
Now looking for a local automotive paint supplier...
Gilles & Kathy
Old 02-14-2011, 04:14 PM
gtc gtc is offline
abides.
gtc's Avatar
I have a wire brush dremel bit that does a good job of removing paint that is stuck deep in the recesses of the wheels, but is gentle on the aluminum.
Graham
1984 Carrera Targa
Old 02-14-2011, 04:47 PM
RETIRED
Joe Bob's Avatar
Got a pic of the wire brush Dremel attachment? Or better yet the part#? Take a look here.....any of these?
Dremel Wire and Bristle Brushes, Dremel Cut Off Wheels 1/8 Inch Shank
Old 02-14-2011, 04:56 PM
idc1873
coxy's Avatar
Here you go
My Porsche 911 | Wheels and Tyres
Old 02-15-2011, 02:43 AM
I would try the oven cleaner again w/ a plastic scraper, then 600 wet sand, 1000 wet sand then buff-out...
2019 Porsche Carrera T
2014 Porsche Cayenne Diesel
1996 Porsche 911 C4 Midnight Blue Metallic
2004 Porsche 911 40th Anniversary SOLD
1972 Porsche 911 Targa - SOLD
Old 02-15-2011, 05:57 AM
you might try gasket remover as mentioned below:
Removing Powder Coating Quickly and Cheaply -- Chopper Surplus
1982 911 SC 3.0L
Old 02-15-2011, 06:33 AM
RETIRED
Joe Bob's Avatar
coxy......nice write up. How were your fingers afterward? Mine tend to lock up, double joint kinda. Not looking forward to that.
Old 02-15-2011, 09:53 AM
Arizona 911's Avatar
I want to paint the centers of my wheels black like zippy gg's
Old 02-15-2011, 07:24 PM
muck-raker
kidrock's Avatar
Hey Joe Bob,
howzabout some before and after pics?
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 02-16-2011, 03:22 AM
RETIRED
Joe Bob's Avatar
Old 02-16-2011, 08:25 AM
