1980SCMan
Alan Lindquist's Avatar
Why Twin Plug?
I've seen some nice motors on this bulletin board. A few weeks ago there was a gorgeous build by Rothsport, I think. It was a twin plug conversion of a special 3.0 liter motor.
I know that some of the 2.X liter racing motors had a twin plug set-up and the 964 went twin plug. I've seen some 3.0 and 3.2 modified with twin plug.
How much do you really gain for the expense and complexity? Is it about the redline performance or is there a gain across the torque and HP band?
Old 02-16-2011, 11:55 AM
There are HP & torque gains across the whole RPM range as well as crisper throttle response. Further, cylinder head temps are reduced due to less total advance needed for complete combustion.
One also gains some detonation margins and the ability to use a higher compression ratio on pump gas, compared to single ignition.
Some further info is here: Welcome to Rennsport Systems, Porsche Performance Products for the 21st Century
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-16-2011, 12:00 PM
Bill Verburg's Avatar
it's all about managing the combustion process, and it is necessary all the time, sometimes more than others.
W/o twin plug cr must be lowered reducing torque & hp. w/ twin plug cr can be raised and more aggressive spark timing and fuel maps can be used raising hp & torque.
w/ twin plug the combustion is started at 2 sides of the combustion chamber at the same time, making the flame path half as long and also taking up half as much time to complete.
here's an illustration of a typical spark event from Bosch
and here is the timing of a combustion event, w/ twin plug you have 2xs the time to manage the event
Bill Verburg
Old 02-16-2011, 12:05 PM
Beat me again Steve
Bill Verburg
Old 02-16-2011, 12:06 PM
abit off center
cgarr's Avatar
And it looks
______________________
Craig
G2Performance
Old 02-16-2011, 12:16 PM
1980SCMan
Steve - thanks for the quick reply and I do apologize that I got the name wrong. I should have investigated first. That motor looked awesome. I'm dreaming of getting the same thing done some day.
Old 02-16-2011, 12:17 PM
AutoBahned
RWebb's Avatar
get the heads drilled when they are off - you can then do the distr. switch when you have some $$
Old 02-16-2011, 01:58 PM
RETIRED
Joe Bob's Avatar
Higher compression/hp with lower octane crappy gas....
2012 ML350 3.0 Turbo Diesel
Old 02-16-2011, 02:04 PM
