-   -   Help My 911 is running like crap.... (http://forums.pelicanparts.com/porsche-911-technical-forum/592575-help-my-911-running-like-crap.html)
aigel 02-19-2011 11:35 PM
How old are your wires? Like I said above, if they are over 5 years old, chances are they may be bad. I know they aren't cheap, but they are the next thing to change. Generally you can't see or feel if they start to deteriorate. I would have done the cap, wires and plugs at the same time to save labor time. Now you have to go in there one more time disconnecting and reconnecting them on both ends. :D
G
89cab 02-19-2011 11:41 PM
G
There is a good chance that they are over 5 years old, I have had the car for 4 years..
I will be ordering some up Monday thanks for your help..
stlrj 02-20-2011 12:40 AM
Beru ignition cables will make any 911 ignition challenged. Add rain and the situation becomes magnified.
Cheers,
Joe
89cab 02-20-2011 09:47 AM
Should I buy Beru,Magnacor,Bosch or Clewetts and are Magnacor and Clewetts the same brand because,Clewetts Website sells both?
stlrj 02-20-2011 05:18 PM
Just make sure they're carbon core and not stranded copper.
kidrock 02-20-2011 05:34 PM
89cab, make sure you save all the parts you replaced up to now. If your problem turns out to be different than ignition-related, you will have a stock of known, good used parts that you can use to diagnose future problems....without having to throw money at it.
Many people here like the Magnacore, BTW....the Clewetts have a good reputation as well.
89cab 02-20-2011 08:55 PM
Noted,Thank you
stlrj 02-21-2011 06:22 AM
Also, you might consider sealing your distributor cap at the perimeter where it meets the distributor with Ultra Grey sealant to prevent moisture ( whenever it rains ) from getting inside and causing your problem in the first place.
Another problem area are the rubber boots on the distributor terminals that have a tendency to wick water when wet causing shorts on the cap.
Cheers,
Joe
74 911 w/86 3.2 and no longer ignition challenged
89cab 03-03-2011 03:54 PM
OK,just installed new Magnacor wires,and I have to say removing the old wires was a *****..
there was a fastner under my A/C compressor that I could not get to, in order to remove the old Beru wires,so I had to cut them out,the left side was easy but right sucked..I can feel a big differance it seems like more power, WOW!!! Hasn't rain enough to tell if that was the problem,but I am glad I got to replace them..
hcoles 03-03-2011 05:26 PM
AC compressor is easy to unbolt and get out of the way, I usually get it loose when fishing the ig. wires in/out of there. Is it your opinion that the new wires fixed the problem? Is it running smooth now?
cgarr 03-03-2011 06:19 PM
If it gives you problems again "post 19" I just had a speed sensor puke out finally after chasing an intermittent problem. A quick test will tell but only if it is bad when you check it.
DRACO A5OG 03-03-2011 06:30 PM
Congrats on your fix, just a silly question but when you reconnected the old Beru's did you feel a "Click" when caps were replaced on those new plugs?
I replaced my Beru's too but when installing my Magnacor's I realized one did not click on causing my rough performance.
MH911 03-03-2011 08:48 PM
Here is the thread I referenced back on post 19 concerning the problem with my sensors. Keep it in mind if you are still experiencing problems.
http://forums.pelicanparts.com/porsche-911-technical-forum/545644-need-help-power-loss.html
89cab 03-03-2011 09:35 PM
Yes I did,that kind of worried me they are not a tight fit on the plug side...
89cab 03-03-2011 09:36 PM
Thanks MH911:D
89cab 03-03-2011 09:47 PM
Nice thread, I am with you every time I do a search no one finishes there thread to tell us what the results are from there repairs..I know most people get excited when fixing the problem and feel that it may not help,BUT IT DOES!
Also my next step if the problem returns is to replace the sensors..
89cab 03-03-2011 09:50 PM
MH911 Do you have a good and reasonable mobile Mechanic ,I live in San Jose..Thanks
MH911 03-03-2011 09:56 PM
Tom Amon of Mobile Works West. Do a search on his name, you will read a lot of positive feedback. He also was the guy that did my PPI and had worked on my car several years before I purchased it.
Mobile Porsche Repair - Mobile Works West brings the Porsche Repair SHOP to YOU
89cab 03-03-2011 10:12 PM
Thank you..
89cab 03-17-2011 01:12 PM
Well guys,Looks like the Plug Wires were the problem,so far so good its rained twice and no problems. Thanks for all your help,I will keep you all posted if something changes..
