Toxic
Does anyone know the Bosch part number for the upgraded two wire cylinder head temp sensor? All I have is Porsche p/n
964.606.405.00 and 930.606.013.00 Thanks,
Bruce 88 Carrera Coupe, 12 Dodge Ram Hemi, 69 Barracuda Fastback, 68 Barracuda Convertible 5spd The only substitute for cubic inches is cubic dollar$. |
0.280.130.070
What is the story behind the two wire sensor. What is the upgrade? Is there a thread you can point me to that covers this topic? I had been thinking about replacing mine and would be interested in knowing what options are out there.
Thanks,
Tom '97 Turbo '89 Targa '04 Audi S4 Cab '03 BMW 1150RT |
Toxic
Thanks John, your the best.
Tom, here's the story, http://pelicanparts.com/techarticles/911_cyl_head_temp_sensor/911_cyl_head_temp_sensor.htm
the two wire sensor is the upgrade and the only option. it doesn't rely on thread contact to the head for it's ground. search the archives. there's lots of posts about this. replace the DME relay at the same time and eliminate the two most common running (or not running) problems with the carrera.
Thanks for the info guys. Is the slotted socket by any chance the same size for the head temp sensor and the O2 sensor? That would be too good to be true...
Derk- Curious as to why you wanted the Bosch part number. Is the part no longer available through Porsche? Maybe cheaper? Thanks,
Senior Member
Cylinder head temp sensor is either 13 or 14 mm, and the O2 sensor is a lot larger. Made a big improvement in my car when I went to the new cyl head sensor. Well worth the time and money to replace but a ***** to get to ...
Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Toxic
I got a friend who said he mitt be able to get bosch parts cheap.
