Under the radar
Trackrash's Avatar
NEW 915 parts out of spec or ??
I'm refreshing my '72 915 transmission.
I don't think this is the right bearing.
The new one has a 4 mm thick flange.
The old one has a 3 mm thick flange.
New...Part number 999-052-043-00-M100
Here is the old, original bearing
Then there is the new dog teeth and synchro ring.
It measures 3.381 and the speck is 3.393 - 3.407.
Any advice is appreciated.
Thanks,
Gordon
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-18-2011, 08:35 PM
Senior Advisor
James Brown's Avatar
Not sure but is that measured from the top of the dog teeth?
08 Cayenne Turbo
Old 02-18-2011, 08:38 PM
Under the radar
Trackrash's Avatar
I'm measuring the OD of the synchro ring. The mic is just above the dog teeth.
The old synchro ring or the new synchro ring on the original first gear dog teeth measure in spec.
However the new synchro ring and new dog teeth together are out of spec.
Gordon
Old 02-18-2011, 08:43 PM
Gordon,
You have the correct bearing, the 3mm flange was '72 only and no longer available. Update your bearing clamp to match.
Synchro fit is a common problem with repro hubs. Your measurement of .012" under spec is really not acceptable. It will work, but won't last very long, as it's eliminating alot of effective synchro surface from use. Your choices are return it for exchange or refund, machine the dogs correctly or machine the synchro slightly to fit the hub within specs.
Jon B.
Vista, CA
Old 02-18-2011, 09:50 PM
Geary's Avatar
There is a small 9-degree angle that isn't cut onto replacement factory synchro teeth. This is usually cut after the new teeth have been pressed onto the idler gear.
Gerry Woods has a cutter which will pre-cut this small angle onto your uninstalled ring. Your synchro ring will then be compressed to the proper spec, rather than overly compressed.
Old 02-19-2011, 06:55 AM
Under the radar
Trackrash's Avatar
Thanks for the update.
I can use a lathe to cut the recess in my bearing clamp to 4mm? Any problem with me doing this? I have a lathe, so I guess I need to fire it up.
.....machine the dogs correctly or machine the synchro slightly to fit the hub within specs.
Can anyone show how the dogs are machined? I have a lathe, can this be done on a lathe?
Thanks for all the help
Gordon
Old 02-19-2011, 09:00 AM
sjf911's Avatar
Originally Posted by Werkstatt View Post
Gordon,
Won't this affect pinion depth and require remeasuring it and potentially reshimming the pinion?
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 02-19-2011, 11:56 AM
Steve,
The bearing flange has no effect on pinion depth, though worn clamps and worn shims do. I feel the depth should always be checked and adjusted regardless, as well as backlash and diff preloads.
Jon B.
Vista, CA
Old 02-19-2011, 12:53 PM
sjf911's Avatar
Steve,
So, in effect, as long as the final drive housing, pinion, and pinion shims are all the same and in tolerance, it shouldn't affect pinion depth to change the bearings and retainer?
Sapere aude
Old 02-19-2011, 01:24 PM
On a 915 it shouldn't affect the pinion depth, but it's always best to check regardless.
Jon B.
Vista, CA
Old 02-19-2011, 01:39 PM
Under the radar
Trackrash's Avatar
Has anyone machined the retainer? Would this weaken it?
Gordon
Old 02-19-2011, 01:46 PM
Gordon,
I spoke to Jacques at Scotts Porsche Parts in National City (just south of Sandy Eggo) , he has a new OE early pinion bearing with 3mm flange. Call him at (619)247-7495. Bring your bearings, clamp and problem synchro parts down to him, he has a full machine shop and can get your issues resolved.
Jon B.
Vista, CA
Old 02-19-2011, 01:47 PM
