Send a message via AIM to mercury26 Send a message via MSN to mercury26 Send a message via Yahoo to mercury26
Port Hole in My SC Trunk? Is this Correct??? Mystery, Solved? :)
I pulled the carpet out of my trunk to get some other work done (read rusty battery tray). I noticed the following "port hole" in my trunk but it does not seem right. The item in question is on the passenger side, towards the front of the car under the jack. Does something else go here? A rubber grommet? Something else? Or is this correct?
UPDATE: After verifying that the "mystery item" was not needed. I pulled it off and found no hole or anything else. It was a metal tin type thing (2" x 3") that was siliconed to the car. One of the bizarre things you find in used cars. I have no idea why it was there or what it was for. At least it was not covering some kind of damage or hidden "goody". I guess the rust gremlins lost their door in and out of my trunk.
Old 07-25-2011, 08:36 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Well, I just check my 3.2 it does not have that port under the Jack holder mount.
'85 Carrera Targa
PCA/POC
Old 07-25-2011, 08:43 PM
What do you have there? Just sheet metal?
Old 07-25-2011, 08:44 PM
DRACO A5OG's Avatar
Just sheet metal. Even you bolt there does not look OEM. Is that oil near at the bottom?
'85 Carrera Targa
PCA/POC
Old 07-25-2011, 08:51 PM
I have oil and crud in my trunk. Not sure where it came from, as I just got the car.
Old 07-25-2011, 08:53 PM
DRACO A5OG's Avatar
I would not worry about it, it seems to be sealed well.
'85 Carrera Targa
PCA/POC
Old 07-25-2011, 08:55 PM
I am not worried, but getting other body work done up front. If it is not supposed to be there, then I will have them seal it up with sheet metal and paint.
Thanks,
Chuck
Old 07-25-2011, 08:57 PM
DRACO A5OG's Avatar
Cool.
'85 Carrera Targa
PCA/POC
Old 07-25-2011, 08:59 PM
Looking for more opinions....
Old 07-26-2011, 06:28 AM
Barrpete's Avatar
What's on the other side? Are you sure there's a hole or did a PO just stick that on there with a bunch of RTV for some obscure reason?
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 07-26-2011, 06:35 AM
Not needed, not supposed to be there.
JR
Old 07-26-2011, 06:45 AM
JR
Thanks! I will dig in and see what is there. If there is a hole in the sheet metal (which I think there is) then I will have the body shop repair.
Thanks,
Chuck
Old 07-26-2011, 06:47 AM
Vereeken's Avatar
Cablemechanism to front trunk snapped and PO made an access hole to release the lever, then figured that it might happen again and made an escape hatch?
The headlamp washer pump went tits up and PO was lazy and instead of dissasembling everything in the wheel whell he decided to cut a maintenance hole?
Michel
My dad always found an excuse why not to buy a Porsche, so I guess I am all out of excuses.
Old 07-26-2011, 07:50 AM
Michel
Hole is on the passenger side, the cable and washer pump are on the driver's side. Try again.
Old 07-26-2011, 08:00 AM
Taking it apart is easy
Jerome74911S's Avatar
Looks like a sardine can to me.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 07-26-2011, 08:06 AM
Yes, does look like one. But pretty small, maybe 2 inches width and 3 inches height (at most).
Thanks,
Chuck
Old 07-26-2011, 08:09 AM
air hole
That looks like the inlet hole for the front condenser fan that has been blocked off, hard to tell from that photo exactly where it is.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 07-26-2011, 09:04 AM
Mike Bruns
Wrong spot for that. The hole looks to be on the right side of the car, unless I'm looking at it wrong.
JR
Old 07-26-2011, 09:12 AM
JR
You are correct, as I stated in the initial post:
"The item in question is on the passenger side, towards the front of the car under the jack"
Thanks,
Chuck
Old 07-26-2011, 09:15 AM
skunked's Avatar
My SC does not have anything like that....
maybe it's a Blinker Fluid Reservoir
-Mat
78 911SC
Old 07-26-2011, 09:58 AM
