3/4 operating sleeve, can this be filed?
i just got this off evilbay. kind of worried that it might cause grinding. Can you guys tell if these are too far gone or can they be filed? One side is good, but the one in the pictures is in question.
85 (early) 944 78 sc targa "The fool who wades in doubt will float like concrete" |
the inner flat area on the teeth that first contacts the syncro look pretty worn. they are about 1/8" wide when new, looking from the tip of the tooth and inward. as the sleeve rubs on the syncro surface over time, that area gets longer looking and the sleeve contacts the syncro deeper, higher and closer to the teeth on the gear. post a clear, well lit picture of the inside of the sleeve.
Throw it away and buy a new one.
Keep the Shiny Side UP! Pete Z. |
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Thanks for taking a look John. I searched and read other posts that you've responded too. Glad to see an expert is taking a look at this. I cleaned up the slider better and tried to get some better pictures with light.
See post #3, this thread. The wear on that part is excessive. Pictures #7 & #8 (post#5) clearly show damage to the teeth (metal rolled over at tooth sides/edges).
Please spend some of the afternoon reading... Welcome to Red Line Porsche Wiki - Porsche Wiki Go to left side of page, locate "page tags" and click on "915." Enjoy!
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 02-26-2011 at 12:20 PM.. |
junk, unfortunately. most used ones are. blunt teeth and well worn inner contact surfaces.
Thanks for the input everyone. BTW Peter, I used that site for my disassemble. Very good notes and pictures.
