915 trans rebuild
Since I cant afford a G50 Im going to be looking into rebuilding my 915. Anyone done this job? Is it feasible? Ive done engines but never a tranny. Thanks for any help!
Keep the Shiny Side UP! Pete Z. |
Thank You so much! I'm almost afraid to read it but on the other hand I cant wait to get started because I don't enjoy driving my Porsche anymore because of the very hard shifting.
Senior Advisor
I'm sure after rebuilding the 915, you will be happier than swapping in a G50, lots of work and so-so results. The 915, in good condition, is a great gearbox. Follow Peter's instructions and you can do it yourself. Very rewarding rebuilding these units, but not cheap.
08 Cayenne Turbo |
while your in there, swap your gears to lower ones. Nice improvement!
Certified Southern Dumbass! 83 911SC with 993 conversion, 98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
Just out of curiosity why do the 915's cause so much trouble? Are people abusing them or neglecting them?(preventive maintenance issue)Is there a design flaw?Wrong fluid?Mine only had 61K on it when it needed to be repaired and now it has 89K and needs to be rebuilt.
AutoBahned
maybe the repair was not complete?
they don't cause a lot of trouble, but a lot of people expect them to be something they aren't & use the wrong fluid |
I'm somewhat in the same boat and had lots of trepidation at starting this rebuild. I did jump in, am halfway through disassembly - and the internals of that transmission are not nearly as scary as I thought. Other than some special tools, I'm finding this to be very "doable" if you're at all "wrench-savvy".
Thank you, Peter, for the wonderful wiki. Good luck! |
My '81 SC, for example, was driven by the PO from 85K (when I repaired the 915), to 117K miles. I bought the car then, and my wife and I put 100K miles on the car, then sold it to a friend of the shop. He drove it about 60K miles (always serviced at Red Line), and then sold the car to someone we didn't know. So we were able to track that transmission for almost 200K miles, without problems beyond routine maintenance and a properly working clutch. They are very good transmissions if the right things are done, and the car is driven within its capabilities.
Almost Banned Once
- Peter |
<insert witty title here>
The rebuild is definitely DIY-able. It's a lot of work, but very rewarding.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
I rebuilt my 915 using Peter Z's tutorial. This was my first tranny rebuild and worked out very well. I also was very active on this forum with specific questions during the process. I had to disassemble twice because on my initial assembly, a small detent plunger was placed on the wrong side of the 4/5 shaft. There were a couple of gents on this forum that were a tremendious help and walked me through the troubleshooting.
Pay very close attention to the detail! Take lots of pictures from different angles and carefully organize your components during disassembly. Good luck...mine was actually fun to complete and works flawlessly. Dan |
gearhead
Not really if it's rebuilt properly. Cheap 915 rebuilds frequently see premature failures because corners were cut the first time around. It's part of why the 915 has a black eye in so many circles. Done properly, using Pete's tutorial as a guide, and a 915 is going to cost near the same as a G50 to thoroughly sort.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
AutoBahned
I thought the 915 gears were much cheaper?
gearhead
I wouldn't consider regearing a gearbox part of a proper rebuild. If you're talking new, 915 gears are about 20% cheaper than G50 at $795 versus $995.
Almost Banned Once
Of course the G50 is newer and seems very robust so they don't require the attention a 915 does. (Yet)
- Peter |
gearhead
Of course, that doesn't negate the cost of entry of going the G50 route. You're gonna pay $3000-4000 for a good used (which is possibly a core needed $3000 worth of work) G50 and then also need all the addition stuff to install it. A G50 conversion is going to cost you as much as rebuilding your 915 and regearing it at the same time. Given those choices, many will choose to stick with the 915 and just rebuild it right which will generally include beefing it up with a sidecover and bearing plate and all the other improvements we've seen over time.
AutoBahned
thanks folks - interesting discussion
(of course, my own direct interest is in creating an automotive anachronism by going back in time to the road-racing shift pattern and light feel of a 901/911 - not to get a more modern G50...) |
gearhead
I don't want to get your hopes up, but we may have something soon on our drawing board that would make your dream come true.
