What is a good weatherstrip preservative?
I may have to park outdoors and I'm concerned about the effects of UV and weather on the rubber windshield seal as well as other glass seals or weatherstrip. What is the best product to use?
Some of the Corvette bbs threads mention Krytox grease, but $34 for a two once tube seems a little steep. Any suggestions? Please not Armoral! |
Wurth Rubber care and/or 303. Or you can use straight glycerin.
uhmm you asking how to keep you rubber's wet? ROTFLMAO
all joking aside, a car cover would limit exposure to both interior and exterior parts and finish
Damon @ SERIES 900.com Sunapee NH several 911 variants |
Try Einszett Gummipflege
available at your local BMW dealer, http://www.pelicanparts.com/catalog/shopcart/CARE/POR_CARE_einszt-detail.htm or any good detailing supply house.
CConnor 73E targa 89 Coupe |
19 years and 17k posts...
I have used the Gummi-Pflege, purchased here at PP for rubber seals and weather stripping with good results.
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Liberal Prawn
So - reviving an old thread -
I was looking at my weatherstripping and it is in great shape - and was about to use krytox on it to keep it looking great - because that is what was recommended for all the top seals on the caddy (removable hardtop and convertible) and it has been working well, but has anyone used it on their Porsche? I would imagine weatherstripping is weatherstripping.
'Such are promises - All lies and jest - Still a man hears what he wants to hear - And disregards the rest. Lie la lie, lie la lie la lie la lie' Paul Simon '87 Black Targa "Welpe" • '93 Cadillac Allante "Amante" • Various other boring cars |
Member 911 Anonymous
3M Silicon Paste, found at Marine/Boat Shops
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Schleprock
Agree. I use plain old silicone spray to keep door seals fresh.
Kevin L '86 Carrera "Larry" |
geez, Krytox is not something to play around with.
Gummi and Wurth rubber care both work very well. Something called LVR from the Wax Shoppe is good. Meguire's has a new spray product that looks good too for the rubber exterior trim. |
talcum powder
61 VW Karmann Ghia 63 European Bug 75 Carrera Coupe 2.8L #81 75 911 Targa 2006 Cayenne S Titanium |
I too have used the Gummi-Pflege, purchased here at PP for rubber seals and weather stripping. I had very good restorative results.
I don't know about long term protective properties as it hasn't been long since the treatment, the car is garaged, and the weather here is fantastic!
1975 914 1.8 Last edited by AZAirCooled; 02-23-2011 at 01:33 PM.. |
Groit's Garage Vinyl & Rubber Dressing: Special UV blocking agents protect surfaces from cracking, fading and hardening. Keeps my rubber soft, supple and looking great. Works great on the dash board too. My tires have a satin, non-greasy finish and never looked better. 800.345.5789 Item#11173
Andy Kay Kennedale, TX 817.948.8538 1979 911 SC Euro - Guards Red |
Recreational User
Any commercially available rubber dressing should be fine, but I like 303 Aerospace Protectant because it's cheap, it's available at most LAPS, and all the pro detailers recommend it. I've used most of the popular types and this is my favorite. It's also fantastic as a tire dressing and interior detailer for all plastic, vinyl and rubber. It blocks UV so it's perfect for a car that sits outside a lot.
"laps" ???
Robert Williams 70' 911T |
Local Auto Parts Store
10-4, thanks
Liberal Prawn
I don't quite understand why krytox is a 'scary' thing though - many people with removable hardtops swear by it - it is all over the Corvette, Mercedes, t-bird, and Jeep forums as a pretty good solution to stop the irritating squeeks, and to protect all that weatherstripping. I have liked it on the Caddy.
Fox, I was gonna pack my cv joints with it, but the safety warnings say to use a respirator and gloves, and you need some sort of special solvent to clean it up, unless I am mistaking it for something else (btw was responding to the post previous to yours)
![]() Edit: just thought of Tri-flow synthetic grease. That stuff is friendly to plastic and rubber, and contains teflon. Last edited by rusnak; 02-24-2011 at 11:33 PM.. |
I used to use Krytox quite a bit for lubricating gadgets I built to fly inside the space shuttle in the cabin and spacelab. The solvent is trichlorotrifluroetheylene. I don't think you need to mess with this stuff just for your car it's an unnecessary expensive product ie overkill. I use Mother's back to black it seems to work as well as any of the silicone based products.
Wally in Montreal, Canada My age 50 something,P- Car's age 30 something 2.7 911S PMO 40's , E cams, RS pistons/cylinders, MSD6AL, Pertronix, SSI's, M+K 2 in 2 out. Perfect studs (whew!) |
Northern Motorhead
Trichlorothene is "bad" stuff ... We don't even use it in the aviation industry anymore.It was somewhat replaced with MEK which is methyl ethyl ketone... also bad s**t !
Stick with safe,proven products ... Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
