quick question on install of new struts
1982 sc with bilsteins. Received the new inserts and the directions that came with them say to use molyb-denum grease in-between the sliding bearings. My question...where is the location of the sliding bearings.
Old 03-09-2011, 04:05 PM
Chuck Moreland's Avatar
Remove the old inserts from the struts. Then peer into the struts, you will see two linear bearings. One near the top, the other about 8 inches down. The outer surface of the inserts rides against these.
Chuck Moreland - elephantracing.com - vonnen.com
Old 03-09-2011, 10:28 PM
