Turn Signals No Worky - Help Plz
Turn signals stopped working. No matter right or left, the right indicator on the dash lights up and stays lit, but even the hazards don't work. Changed fuse and round relay. Found box type relay under cowl that showed some heat, changed it with an autozone relay. Still not working. Any ideas. All help and pics are greatly appreciated.
1984 Euro 930S - B&B Intercooler, Headers, Muffler, K27...1973 Detomaso Pantera....1987 928S4.....1987 Mustang GT
Old 08-08-2011, 12:27 PM
Member 911 Anonymous
DRACO A5OG's Avatar
When you say cowl, you mean behind the gauge, correct? Are you sure the AZ relay is the correct one for your car?
Due to the fact the hazards don't work either, I am leaning towards the relay behind the gauge.
Get your DVM and check at the fuse panel to see it you are getting a signal when you switch the signal left or right. If no signal/pulse, re-check that relay from AZ.
'85 Carrera Targa
PCA/POC
Old 08-08-2011, 05:27 PM
Thank You for the response, I will try to check that tonight.
Old 08-09-2011, 10:31 AM
