Desperately need this screw
I just learned that the reason my sunroof motor is not bulling the wires is because Iīm missing the screw on the photo with the blue circle.
I canīt find any online shops that carry it, nor does my local Porsche dealer. Does anyone know where I can get it or if it can be hacked to work without it?
Glenn
Old 03-14-2011, 12:36 PM
That screw is removed to install the mechanical handle, must be to overide the motor when installed. It ll be metric, 4, 5, or 6 mm, should find something sutable at the hardware store. Now, if thats not it, I have seen the rubber connector so shot that it wont work.\
Bruce
Old 03-14-2011, 12:47 PM
If you can figure out the thread size, try McMaster-Carr
Craig
'69 911T
Old 03-14-2011, 06:09 PM
This is what you need:
5mm dia, .80 thread pitch, 7mm long
note shoulder.
Old 03-14-2011, 07:47 PM
If you can't find one anywhere or make one,
I can ship you the one I have. (it's a spare).
Glen Pettigrew
Old 03-14-2011, 07:59 PM
THANK YOU ALL FOR THE SUPER FEEDBACKS!!!
Iīll see if I can get the screw from my hardware store.
Thank you Glen thatīs super kind of you!!! Iīl let you know if I canīt find it anywhere else.
Greetings from cold Norway.
Glenn
Old 03-15-2011, 02:27 AM
totle's Avatar
Hei Glenn,
Where are you located in Norway?
I'm close to Arendal, might be able to help you out to check local
Trond
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 03-15-2011, 02:38 AM
Manual Opening?
I agree with Bruce that that screw is removed in order to use the manual handle. What I do not understand is how it would prevent the sunroof from opening. Does it disconnect the gear train somehow? Have you tried to open the roof with the handle?
’87 Venetian Blue Coupe
Old 03-15-2011, 04:58 AM
The screw acts like a clutch.
With the screw out, you can turn the input shaft and
the output shaft will turn but, any resistance will cause
it to stop turning.
With the screw in, the output shaft will turn even with
heavy resistance.
Glen Pettigrew
Old 03-15-2011, 05:04 AM
Yayy I just found the screw I lost... Thank you all for helping;-)
Glenn
Old 03-16-2011, 01:04 PM
In case you didn't already know it:
You need a thin shim that goes around the shoulder and
a standard lock washer the goes under the shoulder (between
the shoulder and the end of the shaft it screws into).
Glen Pettigrew
Old 03-16-2011, 07:34 PM
@Glen.
Not sure I understand.. I have a small shin that goes between the case and the big gear. And I have a shim that locks the small gear to the top of the shaft that goes into the gear wires....
G
Old 03-17-2011, 03:40 AM
abit off center
cgarr's Avatar
Here is what was under my screw!
______________________
Craig
G2Performance
Old 03-17-2011, 05:06 AM
oh noooo, really, under the screw? I and just when I thought I got all the parts.... Ok thanks Craig;-)
Old 03-17-2011, 05:14 AM
abit off center
cgarr's Avatar
Now my shims are two different thickness. It looks like they do this to adjust the clutch in the drive mech maybe?
Craig
G2Performance
Old 03-17-2011, 05:20 AM
And maybe it is to prevent the clutch/screw to be tightened to much..?
Old 03-17-2011, 05:30 AM
This is how my spare came apart: (note, my shim is bent folded & mutilitated)
Old 03-17-2011, 08:00 AM
@Glen. Thanks a lot! I guess I can get the shims from the hardware store.
Old 03-17-2011, 11:07 AM
