180Deg. X 270 Deg. which way is which?
ok here it goes, I feel soooooo ashamed... The little fuse block in the engine compartment that has three fuses, Well I removed it when I refinished the mounting shelf and normally I would have wrote down the fuse amp sizes but for some unexplainable reason I didn't. I did record the wire locations in relation to the fuse block But, I also noticed Now! the fuse Block is bridged on the back side of the block which links 2 of the fuses together. So here are my Questions;1. which way is the correct orientation of the fuse Block? 2. what are the ampre's of the Fuses and in what order? Thanks Boys and Girls.. Jorge (Targa Dude)
Here you go.
Hope this helps.
Cary 77 Carrera RS w/3.2 #59 73 914S 2.0 AG 73 914 1.7 Driver ( daily driver, under complete rustoration ) 74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor |
This is a perfect example of why this board rocks.
Nice work cary.
-kb- |
Wow! no kidding this place most definately ROCKs BABY!..
Thanks Cary. it looks in the image that 23 and 24 are linked together, is this correct? I have plenty of those blue fuses but I can swear mine had a Red fuse in the mix too. all Smiles here (Targa Dude)
Went and looked at the owners manual. #22 top one should be 5 amp. Opps.........
Without taking it off, can't see it. Does yours have that rivet/thread deal between 23 & 24. If I remember right, that it the bridge. 23 & 24 get their juice thru the generator. 22 gets it, from the Ignition module.
Thanks Cary..
You are the Man!! Mine is exactly like yours. yes I do have the bridge between 23 and 24.. I'm am releaved... phew! Jorge (Targa Dude)
