porman 965 (guest)
Guest
Posts: n/a
I drove my 911/965 turbo from Guildford to Uxbridge on M25/M40, a distance of around 18 miles, with no fan belt it snapped at junction 10 .I was under the assumption that engine relied on ram effect with fan cutting in when in traffic or stationary. Was I lucky or do you think I have damaged engine. I am intending to drive car to garage to have new belt fitted. Should I not or will it be ok.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: 911 Fan Belt and Pulley Replacement
Old 03-20-2011, 10:54 PM
Author of "101 Projects"
Wayne 962's Avatar
Zero miles is what you should drive on a broken fan belt. You're not correct on the ram air function - this is bad advice that you got from somewhere. The cylinders of the engine are cooled by air and nothing else. If your fan belt breaks, then your engine will overheat even if it's just idling. No miles are okay to drive with a broken fan belt - I personally cooked an engine when I didn't realize the lights were on, on the dash. When I pulled over to a gas station and popped the hood, the oil was sizzling in the engine like one of those old Valvoline commercials. 50 miles later I had about 7 pulled head studs and a completely destroyed engine.
- Wayne
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
none
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 03-21-2011, 03:16 AM
a.k.a. G-man
Geronimo '74's Avatar
Don't drive the car, install the new belt yourself. Shouldn't be too hard.
Old 03-21-2011, 03:58 AM
Seems like its a story of asking questions too late....
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-21-2011, 06:18 AM
Recreational User
porschenut's Avatar
If you started with a stone cold engine, you could probably make it 1 or 2 miles before it got above operating temp. Starting warm, 0 miles I would think.
Old 03-21-2011, 09:17 AM
i cooked an old 356 motor with no fan belt. drove maybe 3 miles.
ken
87 targa
Old 03-21-2011, 09:19 AM
no mon no fun
scoe911's Avatar
Lucky
It happened to me but my AC belt broke first...flapping around it then broke my fan belt. I first thought I had run over something and it was stuck in a rear tire. I drove a few blocks before I saw the alternator light...I'm still here...:-) replaced both belts myself... this was back in Aug 07... I have driven many miles since...
1982sc coupe
Old 03-21-2011, 09:31 AM
Model Citizen
herr_oberst's Avatar
How many miles can you drive your 911 without a fan belt?
The same number of miles you can drive without oil.
Old 03-21-2011, 10:17 AM
Diss Member
Quicksilver's Avatar
The fan is forcing an incredible quantity of air through the engine and an aircooled eingine doesn't have a large mass of water to use as a heat sync that might allow you wiggle room.
If you really drove it 18 miles the next step is to disassemble the engine to see how much can be saved. Frankly a used motor will almost certainly be the least expensive choice in this situation.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-21-2011, 11:02 AM
I remember reading a post a few years ago about a 911 that was driven for a while without a belt. Mobil 1 was in the engine at the time and it somehow kept the engine lubed and there was no damage.
Please post the inspection results
Ned Nyna 11
87 Carrera Targa
98 528i BMW
2004 Jetta 1.8T
Old 03-21-2011, 11:37 AM
304065's Avatar
Long enough to pull over, shut the motor off and call the flatbed.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-21-2011, 11:42 AM
Thats why the factory tool kit comes with a spare and the tools to change it.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 03-21-2011, 01:26 PM
Brando
quattrorunner's Avatar
Omg!
Turbo powa!
1977 911s. it's cool
Old 03-21-2011, 01:47 PM
rnln's Avatar
Hey guys, since some of us had this problem with fan belt and many have the famous cracking and fan housing problem. I am thinking that it's should be easy to install a plastic electronic fan there (even keep the stock fan housing in place), the normal radiator fan. What is/are the disadvantage\s?
Just a thought.
Thanks.
Fat butt 911, 1987
Old 03-21-2011, 02:26 PM
Tired Member
DaddyGlenn's Avatar
Just a thought.
Thanks.
Good luck finding an electric fan that can move that kind of volume.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 03-21-2011, 02:32 PM
Alps Adventurer
Traveller's Avatar
He should check to make sure that the appropriate sized belt is on board as well as the correct tools to change it. My 993 tool kit did not come with the 10 mm triple square, 24 mm box end wrench or the 5 mm hex key needed for a belt change. It does now.
Also, he should try this at home and get some practice before actually needing to do it.
All the best,
Alex
1995 Carrera 2 - Speed Yellow - Alps Touring
Member 911 Anonymous
DRACO A5OG's Avatar
I think there is no electric fan that can meet the CFM (air flow) requirements.
'85 Carrera Targa
PCA/POC
Old 03-21-2011, 02:33 PM
Brando
Again, OMG!
Old 03-21-2011, 02:41 PM
Tsunamiboy's Avatar
Our host sells fan belts for something like $6. There is no excuse to not have a spare and the few tools to fix something like this on the side of the road.
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 03-21-2011, 02:45 PM
