Sounds interesting. Please tell us more like how fast, how powerful, how reliable and how much. All this motronic editor stuff is very interesting but would it not be more cost effective to just go with a unichip? They can be retuned very easily too and all the installers have dynos so that saves a lot of guess work and gas during tuning. |
Irrationally exuberant
Did you use/do I need an in-circuit emulator? Did you tease out the formula just from the code or are there references that you could direct me to on Bosch DME theory/formulas? I've managed to find a little bit looking at some old posts to the DIY_EFI list. thanks in advance, Chris chris@a3ds.com Last edited by ChrisBennet; 02-19-2002 at 07:33 AM.. |
I havent delved too deep into this but I wonder how difficult it would be to take all this info and turn it into (x-)*nix capable software.
SMOB PS-Pay no attention to the 'Senior Member' title underneath my name...with little effort anyone can get that ;-). Last edited by Steve M; 02-19-2002 at 08:11 AM.. |
I used a disassembler and a freeware software emulator. I also have a very handy EPROM emulator and a wide-band 02 sensor. There's no one place to get this information really. There are a few good books on theory--DIY_EFI site has a list--but nothing that'll tell you how to tune the IAC pilot control. My favorite books are the Bosch "Red" book and the little yellow Bosch "pamphlets." I wrote a Motronic table editor that does a decent job at displaying values in readable form. It requires some skill to configure--you need to determine the addresses of the tables you want to edit--You're welcome to a copy of it. -doug |
I'm working on this for fun but I have no allusions that if I could edit the DME software that I would be able to a good job of tuning my car with it. After all, years of writing CAD/CAM software hasn't made me a mechanical engineer. Chris |
On the EPROM there's a "air flow meter transform" table that has to be redone to match the new air meter curve. This is the tricky part and I could never explain it in one e-mail. The response curve of the hot film meter looks a lot different from the flapper and can not be done correctly with the existing code so you really have to re-write some code to make it work well. There's an air-temp compensation table that has to be "flattened." You don't need air-temp compensation for fuel because the fot film meter is measuring air mass flow. The newer Motronics with diagnostics require a bit of effort to prevent the new air meter signal from setting error codes but I don't think this is an issue with the '89 and earlier ones. The fuel tables are for fine-tuning. If the air flow meter transform function is done right, the fuel tables will not require much work to get the car running well. Reprogramming Motronic for different injector flow-rates is a real pain, especially on the 964 and newer cars. What makes it so difficult is that Motronic uses injector pulse-width to represent load so injector pulse-width is referenced in a lot of places. -doug |
Something a little better to put in here.
I found a site that has directions for building an eprom reader for 5 bucks: http://www.zws.com/products/epromr1/index.html Anyone care to comment? SMOB Last edited by Steve M; 02-19-2002 at 05:23 PM.. |
The '84-89 units I've seen have used 3 flavors of Eproms: 2716 (2Kbytes), 2732 (4Kbytes) and 27C64 (8K bytes). The latter one is used in '89 for sure and probably late '87 on. One of the readers they have will do 2764's but according to them you could modify their circuit to work with smaller Eproms. -Chris |
... and what about a Real-Time EPROM emulator connected to a laptop and you can do modifications to the values in real time... see here --> http://space.tin.it/computer/lorgler/nonst-e.htm or here --> http://www.racelogic.co.uk/emulator.htm
Normal EPROM emulators start at around US $150.00 I have use some of the emulators to debug/modify/customize some of my home video/audio stuff (my other hobby), never for my car (the most advanced electronics are a couple of relays) Just a wild thought..
Jordi Riera '84 930 (modified) |
Subscribe!
Thanks, Dave 3 Things To Live By - You can't be Too Rich, Too Thin, or have Too Much Horsepower!
drb930, you realize this thread is over 7 years old since the last reply, right??
Mark Hutchinson 1984 Guards red Carrera M491 Factory Turbo-look |
