Easy way to diagnose a erractic running 911?
I've got a 74 911 with an 81 3.0 CIS engine. The car cranks fine cold warm and hot but has a miss at idle and during acceleration almost like it's running on 5 cylinders. The car is a daily driver and hasn't been sitting for long periods of time. Is there an easy way to troubleshoot this to determine whether it's a ignition, or fuel system or other problem before trying to replace parts without knowing. Thanks all.
Old 03-23-2011, 04:29 PM
you see Arthur...
jasonlee's Avatar
start with the plug wires first, make sure they are all connect and in the correct firing order
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 03-23-2011, 04:34 PM
Yes the plug wires are in correct firing order. As a matter of fact both plug wires and spark plugs are like new.
Old 03-23-2011, 04:39 PM
Once warm, at idle, spray the individual exhaust pipes by the heads with windex or the like and see which one is cold. Once you determine the culprit, then you can look to spark, fuel or compression.
Bruce
Old 03-23-2011, 04:40 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Bruce
If your car is in the air that is a slick idea.
I pull the leads from the coil one by one to see which one causes the engine to not run worse. Pull the wire while the engine is off. :-o
Old 03-23-2011, 05:53 PM
RETIRED
Joe Bob's Avatar
Run the engine in a dark garage. Look for arcing plug wires. It's quite a show.....
2012 ML350 3.0 Turbo Diesel
Old 03-23-2011, 06:11 PM
Honey Badger
theFONZ's Avatar
I had a rough idle/rough acceleration below 2000rpm problem on the 78sc I just purchased. I adjusted the mixture a hair richer and that solved both problems. I did not have an exhaust tester so I just slowly tuned it until the idle smoothed out. Then went for a test drive and all is well.
Old 03-23-2011, 08:36 PM
Does you 81 SC engine have a working lambda ECU and FV ?
Paul
Old 03-25-2011, 05:08 AM
