77turbocarrera's Avatar
996/930 rear caliper/rotor question
I'm working on getting adaptors made to mount 996 rear calipers on the rear of my 77 930. My question is can I use the Carrera 4 89-94 *299x24 *rear rotor on my 77?
I would like to retain the e-brake and won't be able to with the 996 rear rotor.
Old 03-30-2011, 05:23 PM
Northern Motorhead
wildcat077's Avatar
That looks like a question for Mr Verburg ...
If anyone could tell you,he's the one !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 03-30-2011, 06:17 PM
Actually they are regular 996 rear calipers which use the same size rear rotor as the 89-94 Carrera 4 *299x24.
Here's a link to the calipers I have - Porsche 996 Brembo rear brake calipers - eBay (item 180626582028 end time Feb-15-11 18:24:35 PST)
Old 03-30-2011, 07:02 PM
Jaskas's Avatar
The original e-brake works ok with 996 rear rotors too.
The brake shoe comes out from drum about 2mm, but it doesnt affect the braking force that much.
Seen here:
Just buy the adaptors from Finland
911-87 mit der 3.6 V-Ram und alles spaß
Old 03-30-2011, 11:02 PM
Why not? I have 996 rear rotors and calipers on my '77. The rotor drops right on, need to drill a hole in the hat to access the adjuster, just a small amount of e-brake shoe not engaged. But still perfectly usable as a parking brake.
The calipers and adapters take a little more work, least on my trailing arms. But they fit.
Consider talking to Instant-G about their kit - that's what I used. If you already have calipers, they're happy to supply just adapters and fasteners and/or custom front hub (lets you use the stock 996 front rotor). Then the calipers are working with the rotors they were designed to use - and a set of 4 of those is $200 drop-shipped..
'77 S with '78 930 power and a few other things.
Old 03-30-2011, 11:05 PM
Out of curiousity, anyone know if the 89-up carrera 4 rotor will work also?
Old 03-31-2011, 11:52 AM
Bill Verburg's Avatar
You can interchangeably use 911 '69-83 rears(290x24) 911 '84-89 rears (290x24) and 930 rears (309x28)
what to use depends on what's in front
964 rear(299x24) and 993 rear(299x24) have different o/s from each other and from 911
from left here are 993 rear, 996 rear and 911 rear
I've never tried to fit a 996 rear on a 911 but If these guys say 996 rears(299x24) work, I believe them probably Boxster rear 292x20 fit too.
Obviously each has a different o/s and diameter and so the caliper adapters would need to be different
Bill Verburg
Old 03-31-2011, 12:42 PM
