Compression Test - Am I ever DUMB!
Oh, boy. I just searched this forum for Compression test numbers and just learned that I maybe did something dumb. We ran a compression test on my buddies RSA track car. Engine was cool(mistake 1) and we did not have someone step on the gas when testing(mistake 2).
We got 205 for four cylinders, one at 185, and one at 190.
Should I scrap these numbers and do it again?
Thanks.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 03-31-2011, 08:34 AM
abit off center
cgarr's Avatar
Try it again: But the number its self is not as important as how close they are to each other as I am sure you know. We can bump up the numbers huge on our 2.7 just by changing the cam overlap.
______________________
Craig
G2Performance
Old 03-31-2011, 08:38 AM
PRO Motorsports
Tyson Schmidt's Avatar
It won't be ideal, but it won't change much with WOT.
On individual throttle bodied cars it makes a huge difference, but on common plenum intakes, not so much.
Being warm will be a bigger issue, so definitely retest.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 03-31-2011, 09:50 AM
T77911S's Avatar
i never do it WOT, mainly becuase it is just me. plus i look at it this way. i am ony using them as a reference to each other, and if my numbers are hi with the throttle closed, they can only get better. plus, as someone said, if the numbers are in the dirt, WOT is not going to make a difference.
i also do the 911 cold. i am not fast enough to do all 6 so the temp of number one is the same as number 6, that in itself could be missleading.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-01-2011, 06:04 AM
