-   -   Engine Drop - Quick Question (http://forums.pelicanparts.com/porsche-911-technical-forum/600402-engine-drop-quick-question.html)
FIG 04-01-2011 12:11 AM
Hi All,
Just a quick one... (stupid I'm sure!)
When doing an engine drop, can the heat exchangers/exhaust take the weight of the engine without damage?
So if I place timber across a small movable stand (rated at 1500lbs) that would be ok? Or do I have to support via the crank casing rather than the exchangers?
Cheers
Joe Bob 04-01-2011 12:18 AM
You can set the engine on the HEs. No problem.....
FIG 04-01-2011 12:41 AM
Thanks Joe Bob!
rusnak 04-01-2011 01:27 AM
I would use the case seam. Reason is that you have to raise the gearbox nose to clear the tunnel. See engine support thread http://forums.pelicanparts.com/porsche-911-technical-forum/401955-supporting-engine-removal.html
JJ 911SC 04-01-2011 02:35 AM
That worked very well.
Took about 20 minutes to sculpted the 4x4 to the contour of the case seam.
The two piece of wood underneath the HE are about 1/2" from them and only there "in case".
I'm working on the next version with a front lifter build in.
http://forums.pelicanparts.com/uploa...1301650305.jpg
http://forums.pelicanparts.com/uploa...1301650365.jpg
http://forums.pelicanparts.com/uploa...1301650467.jpg
rusnak 04-01-2011 08:04 AM
Sweet! That's some hardware there.
FIG 04-01-2011 10:20 PM
Thanks guys...
Nice carpentry work there JJ... want a job? LOL
I guess if I was going to have the engine out and on the HE's for an extended period of time, I'd craft a work of art like JJ has. I'm hoping (once I have all the seals from Pelican etc) to be out and in in a weekend ish?
I've got to get it all sorted in the next month as the car goes off for resto paint!!! Woohoo!
Cheers
