FIG FIG is offline
FIG's Avatar
Engine Drop - Quick Question
Hi All,
Just a quick one... (stupid I'm sure!)
When doing an engine drop, can the heat exchangers/exhaust take the weight of the engine without damage?
So if I place timber across a small movable stand (rated at 1500lbs) that would be ok? Or do I have to support via the crank casing rather than the exchangers?
Cheers
'65 Porsche 912 (painted dash) #451232
'65 Porsche 912 (painted dash) #451425 - 13 days younger
'78 Porsche 911SC - Resto garage queen
Old 04-01-2011, 12:11 AM
RETIRED
Joe Bob's Avatar
You can set the engine on the HEs. No problem.....
2012 ML350 3.0 Turbo Diesel
Old 04-01-2011, 12:18 AM
FIG FIG is offline
FIG's Avatar
Thanks Joe Bob!
Old 04-01-2011, 12:41 AM
I would use the case seam. Reason is that you have to raise the gearbox nose to clear the tunnel. See engine support thread supporting engine at removal
Old 04-01-2011, 01:27 AM
83 911 Production Cab #10
JJ 911SC's Avatar
That worked very well.
Took about 20 minutes to sculpted the 4x4 to the contour of the case seam.
The two piece of wood underneath the HE are about 1/2" from them and only there "in case".
I'm working on the next version with a front lifter build in.
Who Will Live... Will See
Old 04-01-2011, 02:35 AM
Sweet! That's some hardware there.
Old 04-01-2011, 08:04 AM
FIG FIG is offline
FIG's Avatar
Thanks guys...
Nice carpentry work there JJ... want a job? LOL
I guess if I was going to have the engine out and on the HE's for an extended period of time, I'd craft a work of art like JJ has. I'm hoping (once I have all the seals from Pelican etc) to be out and in in a weekend ish?
I've got to get it all sorted in the next month as the car goes off for resto paint!!! Woohoo!
Cheers
Old 04-01-2011, 10:20 PM
