2.7L - How much magnesium?
I have the 2.7L - 1975 engine.
How many % magnesium? Is it cast aluminum magnesium? Someone knows the answer out there?
Remi Jakobsen 911T DP targa -71 (2.7L) Phone: +47 92844671 (Norway) |
AutoBahned
you want the composition of the alloy?
it has been posted for the Fuchs wheels - not sure re the case if that is what you want, try a search on alloy + case + 2.7 +mg + magnesium you may have to look in Frere's book or Aichele's engine book |
Senior Advisor
Let's just say a 2.7 is magnesium as compared to the 3.0 that aluminum.
08 Cayenne Turbo |
76 911S Targa
I a thinking that Remi is the guy who cracked off the corner of his engine case where the oil pressure sender is located. He is trying to find the right alloy for a TIG weld to get the hole filled. Am I right Remi?
Senior Advisor
Oh yes I remember now.
08 Cayenne Turbo |
Correct: Want to repair with HTS-2000
ANSWER: Hello Remi, If it is over 65% magnesium like some chain saw covers then no, however if it is cast aluminum magnesium which most parts on a vehicle are then yes. You can see more information, testimonials, a video or place your order at Aluminum Welding - Aluminum Repair - Aluminum Brazing - AluminumRepair.com Sincerely, Robert New Technology Products
Almost Banned Once
I vaguely remember the later air cooled VW cases were about 40% Magnesium but that depends on what year.
It may be the same for a Porsche case but I'd be guessing. BTW: Those VW cases would burn like crazy of you got them hot enough
- Peter |
76 911S Targa
Remi,
You should be able to get a small sample to an analyticaL lab for testing. Around here, a sample can be tested for about $60 for four or five elements using spectral methods, AA or ICP. That would give you a certain answer as to the composition of your case. With all the oil business in your country there must be many such testing laboratories. Probably the correct information is archived somewhere though it might require a trip to a good technical library. Lesen sie deutsche? I am curious as I have a 2.7 which is likely made of the same alloy though I haven't broken any pieces, yet. Al |
You have information in german?
76 911S Targa
Nein! But I bet the engineering library at one of the local universities has that information. Another option would be to ask the professor of metallurgical engineering at that institution how/where to find the data. These guys love real world questions.
Max Sluiter
I think it is more like 90% Magnesium.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
The only two references I found for the magnesium alloy of 911 engine cases differ. Ludvigsen says AZ81 alloy was used when Mahle began engine case production; Paul Frere claims it was AZ91. The letters AZ refer to aluminum-zinc, the two main alloying elements; the numerals are the rough percentage content of each. Thus magnesium alloy AZ81 would have roughly 8% weight aluminum, 1% weight zinc, and AZ91 roughly 9% weight aluminum.
Jon B. Vista, CA |
76 911S Targa
Good job Jon! I looked up Ludvigsen and he lists two magnesium alloys used by Porsche, ZE41 and AZ81. The ZE41 was used in the early 60s in race cars. Production cars used the AZ81 magnesium alloy for engine castings. Here is a wikipedia reference for the alloys. Basically if Remi gets some filler for his TIG that is 90+% magnesium and 8% zinc he should be close enough to weld his case back together. Turn up the argon! Magnesium alloy - Wikipedia, the free encyclopedia
Thank you. I need to look up an very experienced welding expert then.
Max Sluiter
I thought it ws ~90% Mg.
The last time I had to weld up a mag case I sawed off a piece from a junk mag case and used it as filler rod. It worked fine.
aws |
An old warped lower valve cover may work good and be cheap?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Just be aware the early valve covers were aluminum and you need to use the mag case covers. If memory serves me right I cut off a piece of the flat area below the distributor hole... but I think any of the mag parts--chain housings, valve covers, vent cover, chain housing covers, would work.
aws |
